Old 21-04-2007, 01:00 PM   #1 (permalink)
Default Problem with D915GLVG
My configuration is as follows:
P4 2.66 GHz, D915GLVG MB, 512 MB DDR RAM, 80 GB SATA HDD, 40 GB PATA HDD, SCSI Yamaha CD Writer, LiteOn DVD ROM, LG 17" LCD TFT...
I use APC UPS 500VA. My pc was working without any single problem for last one and half years.
Day before yeaterday, it refused to start. When I pressed the power button of cabinet, the LCD glew but nothing happened. So I doubted on the SMPS and it was actually not working.
After changing the SMPS, the PC starts i.e. Fans of SMPS and CPU are working, one additional fan attached for cooling is also working, but nothing is displayed on the monitor, it shows "no signal". I tried to remove each components like HDD, RAM, CD/DVD drives, but nothing happens.
What could be wrong? Any hints? Or my motherboard is dead?
jnpandya is offline
Old 21-04-2007, 02:30 PM   #2 (permalink)
Phenom II X4 920 Owner
prateek_san's Avatar
Default Re: Problem with D915GLVG
check ur VGA connector....ie the monitor cable connected to ur CPU......
"A strong positive mental attitude will create more miracles than any wonder drug." - Patricia Neal
prateek_san is offline
Old 21-04-2007, 02:32 PM   #3 (permalink)
The VGA Cable is fine. I tried to reinsert it several times after cleaning, but no help.
jnpandya is offline
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
