Old 21-04-2007, 02:27 PM   #1 (permalink)
Default Pc From Usa
hey guys.. im planning to get a desktop pc from usa soon..
and, i want to use it for mid-end gaming
my budget is like 650 US$
Should i get it customized from Dell or HP or Lenovo or Acer , or i should get it assembled? I was thinking of gettin branded one this time..
can anyone suggest me config etc. Which will fit in my budget ? i need it for games such as nfs carbon, and some fps too.
Karan
help ?
karan_c1990 is offline
Old 21-04-2007, 06:59 PM   #2 (permalink)
thunderbird.117
Posts: n/a
Default Re: Pc From Usa
There is no point getting a PC in US. Mainly because of the warranty card . If you dont have problems with it. I will give you a config list.
Old 21-04-2007, 07:26 PM   #3 (permalink)
sivarap's Avatar
yeah no point in buying from US. Infact teh shipping will cost u more than u try to save. Get the parts here and assemble. Or pay me...i'll assemble it for u []
sivarap is offline
Old 21-04-2007, 07:39 PM   #4 (permalink)
Google Bot
Pathik's Avatar
yepp... getting a duty free lappy is easy but a whole pc is another thing...
rather get it from local shops...
Pathik is offline
Old 21-04-2007, 08:06 PM   #5 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Yeah, a 2GB RAM Core 2 Duo and 80GB HDD with Vista Basic Dell Laptop is selling for 720$ so that would be a better choice to get
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 21-04-2007, 08:25 PM   #6 (permalink)
Google Bot
Pathik's Avatar
^^ u talkin abt 6400 or m1210???
Pathik is offline
Old 21-04-2007, 08:33 PM   #7 (permalink)
thunderbird.117
Posts: n/a
80GB?. Even 80 GB is not sufficient. It is better to get 320 GB Hdd.
Old 21-04-2007, 08:38 PM   #8 (permalink)
Host4Cheap.org
It 6400
Yes, 80GB is kinda on low side but you have take into consideration the OP budget. He said he can spend 650$ so 720$ is some where near. 320GB will put it beyond his limits
Old 21-04-2007, 08:53 PM   #9 (permalink)
Google Bot
Pathik's Avatar
320GB in lappys is still a rich dream... normally 160gb is the max affordable...
Pathik is offline
Old 21-04-2007, 10:42 PM   #10 (permalink)
Is there any laptop HDD with 320GB capacity?
V.Prem Kumar
janitha is offline
Old 21-04-2007, 10:52 PM   #11 (permalink)
UbuntuUser
cynosure's Avatar
^^These two laptops are using 320GBs but it aint exactly 1HD, 2x160GB make it 320GB
http://h41306.www4.hp.com/section?SI...23&secid=55802
http://h41306.www4.hp.com/section?SI...23&secid=58305
cynosure is offline
Old 22-04-2007, 12:01 AM   #12 (permalink)
aryayush's Avatar
3.56 KGs!!!
aryayush is offline
Old 22-04-2007, 08:57 AM   #13 (permalink)
u can bring a loaptop from USA , those r really cheap there....or ipods,xboxs,wii but why u want to bring a PC from usa ? what application u want to do so that u think that 'indian' PC cannot ?
i strngly recommend u to buy everything from india ....bring a graphics card from USA .
reddragon is offline
Old 22-04-2007, 12:35 PM   #14 (permalink)
I already got a laptop from there last year ( dell e1505/ 6400) with a high config.
Ok i'll tell u guys what actually happend now, my uncle works there so he's gona send me a gift (free obv lol) , first i thought the PS3 cuz its the ultimate console.. but then i changed my choice to xbox 360 because:-
1) PS3 doesnt hav piracy and i cant afford 3000 RS per game.
2) To play PS3 in HD i need a HDTV whereas to play 360 in HD i just need a normal monitor because 360 supports VGA out.
So then i came to the conclusion to buy a 360 , but then i thought i might get a desktop pc too which may do many more things plus play games, i thought i can get a mid-end pc from there and then upgrade it here later on when i can save up some more cash.
Its nothing like i hate stuff from India, i know everything is available here now esp. Tech stuff.
So what do u guys suggest ? To go for xbox 360?
Karan
Old 22-04-2007, 12:47 PM   #15 (permalink)
napster007's Avatar
definately go for xbox its the best option for a situation like urs. but there are quite a good pc's in us for ur good range. and i dont think hardware will trouble shoot soon. but since ur into gaming-------------- xbox definately.
napster007 is offline
Old 23-04-2007, 01:36 AM   #16 (permalink)
oh .. ok , some more suggestions?
umm??
Old 23-04-2007, 01:43 AM   #17 (permalink)
thunderbird.117
Posts: n/a
Karan
If you need X360 you need to mod the consoles to play the priated game.
Old 23-04-2007, 01:44 AM   #18 (permalink)
Talking Re: Pc From Usa
yeah man i have alot of knowledge bout consoles... was just asking what would u do if u were in my position ?
Old 23-04-2007, 01:55 AM   #19 (permalink)
thunderbird.117
Posts: n/a
I would not trust on a consoles. Why because there are many things to think when getting a console from US. If you face any problems with the consoles you will not able to repair in india. And if you have a modded consoles you have to forgot about warranty.
Old 23-04-2007, 01:58 AM   #20 (permalink)
I dont really care about all that, i never faced any problem with any console.. i dont care about warranty too, never needed it for consoles..
xD
Old 23-04-2007, 02:01 AM   #21 (permalink)
thunderbird.117
Posts: n/a
xD
Then get what you wish.
