Old 20-04-2007, 02:19 AM   #1 (permalink)
Default Not detcting sata drive...
My computers not detecting my new seagate 160 gb SATA drive .I get a booting disk not detected message when its connected.I dont want to make SATA the boot disk and want to boot from my older drive.The guy from whom i bought who is also helping me install says the only way to solve this would be to reinstall my windows XP and use SATA as the booting disk.I prefer to not reinstall windows so is there any other way??
My OS:Windows XP
Mobo:Asus A8n-SLI SE
EDIT:From what the guy helping me install this said,i think the SATA drive is appearing in bios.
Thanks.
Caesar is offline
Old 20-04-2007, 02:37 AM   #2 (permalink)
shantanu's Avatar
Default Re: Not detcting sata drive...
change the boot configuration in BIOS.. set the first boot device to older drive !! thats all you got to do.. and also check for the SMPS(maybe two drives are consuming more power)..
how much watt your SMPS is ... and also tell your system specs... and which version of windows XP r u using... (means if SP1 or SP2 is not installed then SATA wont get detected in windows too)
shantanu is offline
SATA ROCKS : Fujitsu intros first 2.5" 7200 rpm hard drive with SATA 2.5 interface techtronic Technology News 7 22-03-2009 11:09 PM
Can I attach a new sata drive to my existing Seagate 80GB SATA HDD? praka123 Hardware Q&A 6 04-02-2007 06:28 PM
BEST SATA DRIVE Prajith QnA (read only) 4 08-07-2005 11:44 AM
Problem wth SATA drive. imported_tabrez QnA (read only) 4 12-06-2005 12:58 AM
Sata Drive setting problem taran QnA (read only) 1 07-10-2004 02:56 PM
