Old 19-04-2007, 07:50 PM   #1 (permalink)
Always Questioning?
emailaatif786's Avatar
Unhappy System Death
While powering ON the system, the motherboard gets Green light inside, and then nothing happens, What can be the problem?
:smile: Love Digit
emailaatif786 is offline
Old 19-04-2007, 08:00 PM   #2 (permalink)
assasin's Avatar
Default Re: System Death
its most probably a psu problem.test with a good working psu.
then check ram.clean the ram slot and the ram module contact points with an eraser.
assasin is offline
Old 19-04-2007, 08:26 PM   #3 (permalink)
Google Bot
Pathik's Avatar
yep check the PSU connections and the Ram
Pathik is offline
Old 19-04-2007, 11:35 PM   #4 (permalink)
Always Questioning?
Question Re: System Death
I don't think that PSU has the problem, as it is working fine from past 3 years, Now I have also Re-Cabled the Power cables, won't they affect?
If you are telling me to buy a new power supply unit, how much it costs?Average Cost?
:smile: Love Digit
Old 19-04-2007, 11:48 PM   #5 (permalink)
Laptoping
Sourabh's Avatar
If the motherboard shows the green light, PSU should be just fine. Check the RAM sticks. Do you hear any beeps?
Sourabh is offline
Old 19-04-2007, 11:50 PM   #6 (permalink)
gsmsikar's Avatar
yaar what they all are telling is the correct steps ...
try it first ////
gsmsikar is offline
Old 19-04-2007, 11:52 PM   #7 (permalink)
Still Shining!
Lucky_star's Avatar
Remvove the CMOS battery, then remove the RAM sticks, clean the board and reinstall all again.
Nokia N86 8MP
Lucky_star is offline
Old 20-04-2007, 02:10 PM   #8 (permalink)
Always Questioning?
Unhappy Re: System Death
Yeh, Only ONCE there were BEEPS, but NO Video, then after restarting Power Button, there was NOTHING.
I changed the RAM from 1 slot to another, but nothing happened.
I took out the Battery from > 2 Minutes, but nothing happened.
I re-cabled the motherboard, but nothing happened.
When I Power ON the UPS > Power Supply .. only Small Green button on the MotherBoard Lights, and happenes.
:smile: Love Digit
Old 20-04-2007, 02:40 PM   #9 (permalink)
Laptoping
Sourabh's Avatar
Repeated long beeps = Memory Problem
Replace the RAM and the problem should go away. Get a test piece before buying a new one, just to be sure.
Sourabh is offline
Old 20-04-2007, 02:43 PM   #10 (permalink)
Always Questioning?
I THINK there were 3 beeps, after then Only FloppyDrive Sound and repeat restart, with NO video.
Now Only green Light on Motherboard.
:smile: Love Digit
Old 20-04-2007, 05:48 PM   #11 (permalink)
a_g = JPKN
s18000rpm's Avatar
@emailaatif786, do this^ step & report back.
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 20-04-2007, 08:35 PM   #12 (permalink)
Always Questioning?
I checked the PSU by Short-Circuiting Method, and it showed error.
There is a problem with PSU.
Thankyou all
:smile: Love Digit
Death in Sakkara siriusb Gamerz 4 08-11-2005 10:39 PM
