Old 19-04-2007, 06:04 PM   #1 (permalink)
Unhappy DVD Writer Read Problem in XP
Hello Frnd,
My pc got a ultra problem, i got new dvd writer of sony and installed it on my pc but its not reading any cd/dvd on operating system XP but when i installed 2000 prof then its working fine, i also tried it on my frnds pc win 98 installed on that its working fine. its only giving prob with XP. I installed XP with help of this DVD, here its also wrking fine. i tried two different copies of xp but result is same. I don't know what is going on. Plz help me out. My Machine confi is Processor 2.80 Dual Core, M/B : D102G, 512 DDR2 Ram, 80 GB Sata, Sony CD-Rom and Sony DVD Writer.
klerajay is offline
Old 19-04-2007, 06:55 PM   #2 (permalink)
Alive Again...
satyamy's Avatar
Default Re: DVD Writer Read Problem in XP
Possible your cable which connects your DVD Writer to Your Motherboard is gone bad
Use a Good Quality 80pin conductor Cable
Last month i replace mine for the same problem
it will cost you around Rs. 60/-
satyamy is offline
Old 21-04-2007, 10:00 AM   #3 (permalink)
Smile Re: DVD Writer Read Problem in XP
i changed the dma settings and now its wortking fine in xp. thanks for reply
klerajay is offline
combo drive problem read some dvd dosen't read others q4_abhi Hardware Q&A 4 03-04-2007 05:09 PM
XBOX read problem.. ganesh_2218 Software Q&A 1 11-12-2006 08:50 AM
read only problem imrans Software Q&A 4 16-08-2006 08:03 AM
iPod battery problem? Read on... Febians Technology News 1 26-11-2005 09:07 PM
DVD Problem-Cant Read DVD's karthik_rcs QnA (read only) 13 21-03-2005 04:04 PM
