Old 19-04-2007, 02:43 PM   #1 (permalink)
Smile Portable hard disk,20GB
Which is the cheapest portable hard disk available in the market. Please tell about features as well.
ThinkFree is offline
Old 19-04-2007, 03:44 PM   #2 (permalink)
Default Re: Portable hard disk,20GB
cheapest will be...buy an ordinary HDD and a cover for portability( which have USB to bus coonection ) ...that will be cheapest . hard disk's only feature is storing data . I dont think it have some other features , well depending on the disks u may get SATA , pata, 5400rpm 7200 rpm or 15k rpm .
pkt3000 is offline
Old 19-04-2007, 04:05 PM   #3 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Yep, buy an Internal Harddrive, and use the USB External Case and you will have a nice External HDD which can be used as internal if the need arises
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 21-04-2007, 10:01 AM   #4 (permalink)
It would be better if you mention prices as well
Old 21-04-2007, 10:10 AM   #5 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
for prices....whatever's the price of the hdd+500 buks(approx) for the case.
refer to www.theitwares.com for hdd prices
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 22-04-2007, 10:01 PM   #6 (permalink)
u have 2 options for HDD's :
3.5" HDD ( it requires an external power supply ) - the usual desktop HDD
2.5" HDD - gets power from the USB port - laptop HDD
not too sure about the prices ,but i think u can get 40GB 2.5" well within 3k
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 22-04-2007, 10:29 PM   #7 (permalink)
Host4Cheap.org
Yes, i bought 80GB Laptop Drive with External Casing for rs 4400 about 4 months back
USB Cable for Portable Hard Drive abhijitroy Hardware Q&A 4 20-01-2009 06:40 PM
all files from IDE hard disk with windows 2000 to SATA II hard disk with windows jagadish2005 Software Q&A 8 10-04-2007 11:08 AM
Making portable hard drive blademast3r Hardware Q&A 8 24-02-2007 06:03 PM
Portable hard disk Angad singh Hardware Q&A 4 28-11-2006 09:32 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
