Old 18-04-2007, 10:34 PM   #1 (permalink)
slash_89
Posts: n/a
Default USB problem.
my config:-
amd athlon64 x2 3800+,
asus m2n pv-vm,
1gb ddr2 667mhz transcend ram,
yamaha ds-xg soundcard,
onboard geforce6150
this rig is only a month old,
i have a 128mb intex pendrive, it worked fine at first but now an error saying "Unknown device",
but the pendrive works fine on my friends pc,
and when i view the device manager, under the PCI Bus theres an Unknown Device,
i even reinstalled xp, but to no avail,
what driver should i put? since i have SP2 usb driver is not required right?
im really worried sick abt this pc cos its just a month old not to mention the prob with that harry potter game i mentioned,
plz help.
Old 19-04-2007, 08:20 AM   #2 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
Default Re: USB problem.
re-install the usb drivers, make sure u have windows installation cd as well as ur mobo cd
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
