Old 18-04-2007, 06:30 PM   #1 (permalink)
Default plz help me out!!
here is my config:
Pentium D 3.4Ghz
Asus P5LD2-VM-CR-SI 945 G mobo with onboard graphics
512Mb DDR2 400Mhz ram
Western Digital 160 GB 7200RPM HDD
LCD monitor
DVD writer
300W power supply
My question to u guys is that can if i install an 8600GT 256MB card without replacing the SMPS and also upgrade the ram to 1GB, what kinda problems will i face? are there any serious probs??
And i have an old joystick which requires a game port but since my mobo doesnt have one i wanted to know if there is any kinda adapter available which will enable me to use this joystick thru an USB port.
And lastly will i be able to play Flight Simulator X on this config??
eagerly waiting for ur replies!!!!!
undertakerthedead is offline
Old 18-04-2007, 06:35 PM   #2 (permalink)
Default Re: plz help me out!!
I don't think there should be any problem, but if you have some cheap quality SMPS you should consider an upgrade!!
Good luck
jack// ani is offline
Old 18-04-2007, 06:52 PM   #3 (permalink)
The Unknown's Avatar
RAM
Problems can come if you upgrade RAM to >256. I had a 200W SMPS. Computer used to freeze frequently with 256 RAM. But after i upgraded to 400W; all freezing vanished. Now i hv 384 RAM. Still no prob.
Joystick-
You can either install an old type of sound card to get it or consult some enginner for the converter.
KDE on ArchLinux
The Unknown is offline
Old 18-04-2007, 07:12 PM   #4 (permalink)
thnx a million for ur replies.
anybody else too????????
Old 18-04-2007, 07:26 PM   #5 (permalink)
Super Saiyan
Goten's Avatar
Better change ur SMPS if its cheap n go for a gud one from zebrinics n all n yeah ask ur vendor wich suits G8x the most.
Power issues shud never b neglected it may hamper ur card motherboard n even sometimes performance.
Peace~~~!
Goten is offline
Old 18-04-2007, 10:12 PM   #6 (permalink)
thnx for telling me abt the problems with the graphix card but what about ram and the last part of my question about flight simulator X??
Old 19-04-2007, 05:04 PM   #7 (permalink)
I don't think there should be a prob. but you should upgrade your power supply to atleast 400W.
abhijangda is offline
Old 19-04-2007, 05:53 PM   #8 (permalink)
Do umean to say that there wont be a prob with the graphix card or do u mean to say that i will be able to run Flight Sim X on this????
Old 19-04-2007, 06:38 PM   #9 (permalink)
Hey, are you telling me?
KDE on ArchLinux
Old 19-04-2007, 06:42 PM   #10 (permalink)
lol....yeah u and jack// ani.
Old 19-04-2007, 06:47 PM   #11 (permalink)
Why? was i wrong?
KDE on ArchLinux
Old 19-04-2007, 09:32 PM   #12 (permalink)
Smile Re: plz help me out!!
no no no i seriously meant it.
Old 20-04-2007, 05:35 PM   #13 (permalink)
meant what?
KDE on ArchLinux
Old 20-04-2007, 07:25 PM   #14 (permalink)
ok here i go again... thank u for the advices u gave me. plz just cool down...am not pulling ur leg!!!!!
Old 20-04-2007, 08:49 PM   #15 (permalink)
ancientrites's Avatar
here is my config:
Pentium D 3.4Ghz
LCD monitor
DVD writer
300W power supply
the smps is the only problem.i suggest you buy a 500 watts smps from zebronics or 450 watts from vantec.
ancientrites is offline
Old 21-04-2007, 05:54 PM   #16 (permalink)
You are funny.
KDE on ArchLinux
Old 21-04-2007, 06:57 PM   #17 (permalink)
thunderbird.117
Posts: n/a
here is my config:
Pentium D 3.4Ghz
LCD monitor
DVD writer
300W power supply
Yes you can install 8600GT. Also you should remove your SMPS and RAM. Get a 500W smps and (512*2)1 GB or 2 GB. If you add your graphics card to your 300W be ready for crash and stability of your system and lastly your SMPS will burn. So get a 500W so that your system wont be under risk.
Sell you joystick and get a gamepad.
Yes you can play Flight Simulator X on your system if you have a card.
