Old 17-04-2007, 08:21 PM   #1 (permalink)
Default can I add a new fan myself?
can I myself add a new fan @ my cabinet ? I havent seen anyone fixing a fan tilldate but have anyone here tried it ? otherwise I need to call a god damn mechanic .
pkt3000 is offline
Old 17-04-2007, 08:29 PM   #2 (permalink)
Default Re: can I add a new fan myself?
its simple, I did it last month connected 3 of them to my mobo, if ur moboc does not have fan socket the u wil have to connect to the 12 v plugs coming from ur power supply.
ranjan2001 is offline
Old 17-04-2007, 08:55 PM   #3 (permalink)
ok so I can understand from motherboard side its ok ...but how to fix it approatly on the wall of the cabinet ?
pkt3000 is offline
Old 17-04-2007, 09:21 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
i think U need a cutter for that.
ravi_9793 is offline
Old 17-04-2007, 09:22 PM   #5 (permalink)
Proud Mac Pro Owner
nepcker's Avatar
Check this link:
http://www.avsforum.com/avs-vb/archi.../t-555644.html
Microsoft Certified Professional Mac Addict
nepcker is offline
Old 17-04-2007, 09:31 PM   #6 (permalink)
either ur cabby should have an option for fans, (mine has cuts for 80mm) or u need to make a cut, just take the cabby to some gud lathe machine guy & explain it to him, rest he will do, take the mobo out from the cabby before that.
