Old 16-04-2007, 07:26 PM   #1 (permalink)
Default pc hangs just after 2-3 mins of startup
tell me what to do . My PC hangs just after 2-3 mins of startup. I am doing nothing . Not a Virus problem I think because updated Bitdefender registered version is already there. I formatted C drive . reinstalled windows . Now the PC is starting but after 5 mins only i mean it is taking 5 mins to start . and bootup process is very very slow ( it is showing some coloured dots for 1-2 seconds but just 1 time ) . then it is coming standstill after some minutes .
pkt3000 is offline
Old 16-04-2007, 08:30 PM   #2 (permalink)
Default Re: pc hangs just after 2-3 mins of startup
Hi,
1. Did u check ur processor is running ?. I hope that is problem
thanks
Jagadish
jagadish2005 is offline
Old 16-04-2007, 08:52 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
have you added any new hardware???
ravi_9793 is offline
Old 16-04-2007, 09:19 PM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
@ pkt3000
First post your hardware config in details and which windows version you are running -- it will help you & us to troubleshoot your problem easily.
I think your ram or HDD is faulty. so check them out
If U use a graphics card check that too
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Internet gets disconnected after 5 mins.. ssk_the_gr8 Internet & WWW 3 16-02-2007 04:36 PM
Ghost~Instals WinXP in 3 mins debiprasad_sahoo Software Q&A 28 26-07-2006 12:56 AM
Contra in 12 mins!! Febians Gamerz 4 07-12-2005 03:28 PM
20 Mins 213 MB; 1hr 650 MB+ Maverick340 QnA (read only) 12 27-10-2005 12:23 AM
PC Hangs After every 5 mins killerguy QnA (read only) 6 26-12-2004 10:20 PM
