Old 16-04-2007, 09:35 AM   #1 (permalink)
56561's Avatar
Thumbs down SMPS trouble ? or ....
my cabinet is Zebronics antibiotic . in this summer because of excessive heat my PC got some sickness . I am not getting what it is actually . what happens is that some sudden restarts then after loading windows it get freezes ...also it is working very sluggish ...................I have 1 gb ram , previously it was very fast . I reinstalled windows then also the problem remains ........ should I change my SMPS ?
56561 is offline
Old 16-04-2007, 09:42 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: SMPS trouble ? or ....
have U added any new hardware to ur cabinet??
I think you need to have a extra fan rather than changing SMPS.
ravi_9793 is offline
Old 16-04-2007, 02:46 PM   #3 (permalink)
Post your configuration and wattage and brand of your SMPS.
V.Prem Kumar
janitha is offline
Old 17-04-2007, 09:44 AM   #4 (permalink)
56561's Avatar
my config is AMD venice core 3000+ , MSI RS 482 ILD motherboard , 1 gb ram , liteon DVD writer , sony flopp disk , I dont know the brand of my SMPS ....how to get knowledge about the SMPS I dont know ............. even I dont know whats the watt of SMPS .
well I have zebronics antibiotic cabinet ... the 120mm rear fan ( at the behind ) is not working from the beginning that dosent caused any trouble till now....even I have played games like F.E.A.R , HL2 ....... but now it seems that I may need to change it...... so what happened to my PC ? what is the cost of a rear FAN?
56561 is offline
Old 17-04-2007, 09:59 AM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
yes..U need to change the fan...as heat wave high in air.Fan will cost U around 150 bucks
Old 17-04-2007, 04:06 PM   #6 (permalink)
56561's Avatar
what about changing SMPS
56561 is offline
Old 17-04-2007, 06:53 PM   #7 (permalink)
Borrow a good SMPS from a friend and try.
V.Prem Kumar
janitha is offline
Old 17-04-2007, 08:54 PM   #8 (permalink)
TechTin.com
ravi_9793's Avatar
^^^^^^^^U can do give this a try.This is a good thinking .But a fan is must for ur cabinet.
Old 17-04-2007, 09:07 PM   #9 (permalink)
darklord's Avatar
Frequent dumps and crashes indicate towards a RAM problem too.
darklord is offline
Old 17-04-2007, 10:53 PM   #10 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
your ram has most probably gone bad.
check using memtest86 or similar software.
Rollercoaster is offline
SMPS got a Boo Boo :( Thor Hardware Q&A 4 13-04-2007 09:26 AM
Help meee!!20 pin SMPS to 24 pin SMPS? sourav Hardware Q&A 9 25-09-2006 10:37 PM
Fedora Core 4 installed ...... trouble trouble trouble... iinfi Open Source 19 12-10-2005 06:03 PM
SMPS....GIVING TROUBLE sysmaniac QnA (read only) 5 08-06-2005 05:49 PM
Zebronics 500W SMPS. Is it a good SMPS. Advice needed. Yoda QnA (read only) 4 13-11-2004 11:15 PM
