Old 16-04-2007, 07:52 AM   #1 (permalink)
shyamno's Avatar
Default Guys Suggest me ....SATA or PATA..
Guys..I am totally in confused state..in upgarding my HDD..
My mobo supports only PATA HDDs..and I am having 40GB HDD..now I am feeling the heat of Data storage..and I need to add another HDD....
But the question is that...which one should I go for..keeping in mind..my future upgradation of the complete system...
Now if I gor for PATA now..then there is a huge risk ..that I will waste my money..as the PATA..supporting mobo are ..steadily..going out of the market..
Also..if I go for SATA..then how will the combination of SATA and PATA effect my system performance..and also the main question is that how can I add a SATA HDD on a PATA supporting mobo..
So plzzzzz help me out..from my confusing..???Guys need answer quickly..
shyamno is offline
Old 16-04-2007, 08:36 AM   #2 (permalink)
Default Re: Guys Suggest me ....SATA or PATA..
Get sata to pata convertor I got it for 550/- delhi for single sata connector last year when I was in the same problem.
This will connect to ur IDE port on the mobo &will give u 1 connector for sata which can be used easily.
You may feel a 15-20 sec delay in booting as the sata to pata convector needs to get detected , but then how many times in a day do u boot, 15 sec will hardly make a difference.
Sata in external case with old comp
This might help some image links are dead where I posted it from ebay.com but u can search on ebay &it will be shown.
ranjan2001 is offline
Old 16-04-2007, 08:38 AM   #3 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
^^ That converter is a piece of crap.. You wont get any speed boost using it, actually your HDD speed will go down! As for PATA becoming obsolete, that's not gonna happen for a LONG time since all optical drives are also PATA. So just get a PATA drive, there is not much difference in speed of PATA and SATA atm.
kalpik is offline
Old 16-04-2007, 08:40 AM   #4 (permalink)
Yes u wont run sata at its speed instead it will comedown to IDE speed & thus its only ideal for ur data storage, if u need to work on this data regularly then it will slow things due to the convector, read that thread which I posted the link, I used is for 8 months.
Old 16-04-2007, 08:43 AM   #5 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
The price at which you will buy SATA to PATA would actually come somewhere near the Depreciation on PATA HDD incase you upgrade
Had i been in your place, i would go for PATA
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 16-04-2007, 09:47 AM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
I will also suggest you PATA,if you have no plan to upgrade ur motherboard in near future.
ravi_9793 is offline
Old 16-04-2007, 10:13 AM   #7 (permalink)
Sup' dude, Sup'
Just go for PATA HDD. btw, mobo support for PATA will not fade out soon as PATA is still most used for optical drives. Don't worry and take PATA. Instead of paying 500 bucks for converter put that in HDD's budget and you will get more storage. Never rely on PATA <-> SATA converter.
ambandla is offline
pata to sata. sagar_coolx QnA (read only) 5 30-03-2006 06:00 PM
SATA to PATA ra_sriniketan Hardware Q&A 5 27-11-2005 10:43 PM
PATA or SATA anilthomas26 QnA (read only) 8 27-06-2005 02:09 PM
Sata or Pata ...... What is this. godsownman QnA (read only) 19 10-06-2005 06:41 PM
SATA YA PATA nishantv2003 QnA (read only) 19 20-10-2004 11:12 AM
