Old 14-04-2007, 10:24 PM   #1 (permalink)
Default PC very slow
My PC is running slow from the past 4-5 days. whenever i run a game it just dies. My pc runs fine if i run any application or movie. When i checked the system configuration utility i saw an entry "dumprep 0-k". Anywayz i unchecked it and restarted my PC and i am still facing slow speed issues. I dont understand whether its an hardware or software issue or if its a virus.
Kindly help
Thanks
ak24 is offline
Old 15-04-2007, 10:41 AM   #2 (permalink)
Default Re: PC very slow
can u please check in WINDOWS/system32 folder if checkdsk.exe is present or not?
better use a software called speedupurPC2.0
pkt3000 is offline
Old 15-04-2007, 10:50 AM   #3 (permalink)
Distinguished Member
anandk's Avatar
do the usual first !
run ur antivrus and anti-spy in safe mode. run ccleaner. run checkdsk and defrag ur harddrives. also reduce ur startups. see MAKE WINXP STARTUP/SHUTDOWN FASTER ! if all fails post ur hjt log. for more on dumprep click http://www.bleepingcomputer.com/star..._0_k-1449.html
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 17-04-2007, 03:00 PM   #4 (permalink)
deepak.krishnan's Avatar
^^^ yup, as Anand mentioned, do a virus scan first using a reliable antivirus.
.dk
deepak.krishnan is offline
Old 17-04-2007, 09:11 PM   #5 (permalink)
I did a virus scan , checkdsk.exe is present, reduced startups, and also disabled error reporting... but still i am facing the same issue... is this a hardware error ???? will my PC work fine if i format my system ???
ak24 is offline
Old 19-04-2007, 07:49 PM   #6 (permalink)
anandk's Avatar
formatting is ussaually a slotion-for-all probs but get ur hjt lof auto-analysed at www.hijackthis,de or post it here b4 u take a decision.
Microsoft® MVP
anandk is offline
Old 19-04-2007, 11:01 PM   #7 (permalink)
Dreaming Future
kin.vachhani's Avatar
best way is to use hijack this and trace all unwanted services and programs....
then use ccleaner for cleaning the registry...
Is the best way to do it
World without Computer is like a man without Brain.....
kin.vachhani is offline
Old 22-04-2007, 12:16 PM   #8 (permalink)
Formatted my PC and everything is working fine now ..
Thanks
ak24 is offline
Old 22-04-2007, 12:38 PM   #9 (permalink)
Its Best only if its open
ankushkool's Avatar
after using de PC for some time it always gets slow, so i hav 2 format de entire PC then it works fine. why does this happen? please suggest me some utilities 2 keep my PC in best condition. i m using Tune up.
ankushkool is offline
Old 22-04-2007, 11:08 PM   #10 (permalink)
UbuntuUser
cynosure's Avatar
^^ One main coz is that the file is split into diffrent sectors of the HD and if these sectors are far away from each other, then the PC becomes slow as these parts are difficult to reach. For this use Disk Defragmantation.
Other option: Use Linux.
Its only coz of these reason that I stopped using windows. machine becomes slow and you need to format the PC after every 6-7 months, although there are ppl whose PC just dont go slow!!
cynosure is offline
Old 27-04-2007, 07:29 AM   #11 (permalink)
ankushkool's Avatar
is linux de only sol 2 my problem??? r there no tools available in xp 2 solve this prob.
Old 27-04-2007, 03:30 PM   #12 (permalink)
UbuntuUser
cynosure's Avatar
^^ There are solutions.
1)Use Disk defragmenter from start>Programs>Accesories>System Tools>Dsk Defragmenter.
If you have a jumbo HDD then it will take time (on SATA it will be faster than IDE but still it will take quite a time)
Better is that you start your PC in safe mode before doing this as the other programs in the background tend to start the process of DD all over again.
2) Few years back I used a program called "system mechanic". It had a dsk defragmenter, registry cleaner and more things to speed up the PC.
3) Never install the programs in the same partition in which you have installed your OS.
You can use all the programs in the system tools one by one. I dont remember all of them but they will surely help you.
Right now I cant think of more solutions but doing DD will sure increase the speed.
cynosure is offline
Old 27-04-2007, 07:23 PM   #13 (permalink)
delete that entry from registry
My Torrent Speed:-
[img]http://maxupload.com/img/DF44FD59.jpg[\img]
azad_singh is offline
Old 27-04-2007, 09:48 PM   #14 (permalink)
ankushkool's Avatar
Red face Re: PC very slow
1)Use Disk defragmenter from start>Programs>Accesories>System .....
2) ...
r de MS windows tools good enough???
Old 28-04-2007, 11:42 AM   #15 (permalink)
UbuntuUser
cynosure's Avatar
^^ Yes the M$ tools are "kaam-chalau" but you see the third party softwares are always better.
Norton SystemWorks is also good. Buy it. It has many programs to speed up your rig. Monthly checkup using systemworks will keep your PC in good condition.
I mean I have used both the softwares prescribed by me (Systemworks and System Mechanic) and they worked fine (if not wonders) on my PC.
cynosure is offline
Old 01-05-2007, 11:08 PM   #16 (permalink)
ankushkool's Avatar
but norton comes in entire package n installing it seriously effects system performance
Slow XP the_ragman Software Q&A 15 23-10-2006 09:48 PM
Why is my pc slow??? nishantv2003 QnA (read only) 25 26-05-2005 04:26 PM
Slow XP ashisharya Software Q&A 18 13-03-2005 11:26 PM
pc too slow shikhar_kapoor143 QnA (read only) 2 31-12-2004 02:18 AM
Slow navisangha QnA (read only) 10 21-12-2004 05:34 AM
