Old 14-04-2007, 08:41 AM   #1 (permalink)
Default Doubt on Ram
I hav an old pc other than my C2D
Its mother board says it supports
2x184 pin DDR DIMM socket support upto 2GB
Support DDR 333/266 DDR SDRAM
My doubt is that can i use
"128 MB SD RAM(133 MHz)
Upgrading the memory in your PC is the smartest, fastest and most affordable way to boost performance-for every computing task. This Ram is reccomanding for most of the P3 and Celeron PCs with SD Ram sloat.(1 Year Limited Warranty)
Price : Rs. 450/-"
Quoted from comuter warehousepricelist.com
http://www.computerwarehousepricelis...list.asp?ctg=4
Intel Core 2 Duo E6300 1.86 Ghz
Asus P5LD2VM SE
1 GB DDR2 533 MHz Unbuffered Transcend
aneeshkj is offline
Old 14-04-2007, 09:21 AM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: Doubt on Ram
@http://www.thinkdigit.com/forum/showthread.php?t=54998
double posting
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 14-04-2007, 10:13 AM   #3 (permalink)
Sorry for double posting...
Can i delete the other post...
Asus P5LD2VM SE
aneeshkj is offline
Old 14-04-2007, 10:56 AM   #4 (permalink)
=CrAzYG33K='s Avatar
OK - Let that post be deleted..
Mods -- Look into the matter
And NO.
That motherboard supports DDR Memory and you've provided a link for SD RAM.
Best thing you can do is..
Go for 256MB DDR RAM.. Which you'll get in second-hand for about 500 bucks ! That's cheaper than SD RAM...
=CrAzYG33K= is offline
Old 14-04-2007, 11:13 AM   #5 (permalink)
Is there any online shop for second hand rams..
can u give me d link..
Asus P5LD2VM SE
aneeshkj is offline
Old 18-04-2007, 08:32 PM   #6 (permalink)
Try posting in the 'I want...' forum in Bazaar section here ...
http://www.thinkdigit.com/forum/bazaar/
one doubt please mayneu QnA (read only) 5 07-10-2006 01:05 PM
I have a doubt fibermanco QnA (read only) 8 17-09-2006 12:30 AM
hdd doubt... simoncherian QnA (read only) 4 12-06-2006 12:17 AM
...::doubt::... h4ck3r Open Source 6 24-01-2005 07:07 PM
