Old 14-04-2007, 07:13 AM   #1 (permalink)
Default ASUS a7v8x-x ! URGENT!!
I own an ASUS a7v8x-x motherboard and i need to upgrade my hard disk capacity urgently. The problem is i do not know whats the max capacity of the hard disk i can buy( i.e, the motherboard can detect uptil which point)
ideally i would like to buy anywhere between 160 to 250 gbs but i cannot buy until i know that. I have tried going to the asus website and it wasnt of much help.
Any help that you can provide in this regard will be greatly appreciated.
Many thanks in advance.
tamalsen is offline
Old 14-04-2007, 08:22 AM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: ASUS a7v8x-x ! URGENT!!
@tamalsen
u can add a HDD of any capacity. Ur mobo can detect it if u have ny free slot. Does ur mobo has sata ports??then go for a sata 2 one. It wud scale down and run at speeds of sata1[150 MBPS]. Go for a 250 GB sata2 @ 3.5k or 320 GB @ 4.3k.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
ASUS 5900Ultra or XFX 5900 ultra or ASUS 6600 or XFX 6600!!! rachitboom2 QnA (read only) 1 06-03-2005 04:05 PM
ATI Radeon 9600 and ASUS K8N compatibility - urgent!!! sakumar79 Graphic cards 5 09-02-2005 02:44 PM
Problem with recording in A7V8X-MX-SE Choto Cheeta QnA (read only) 2 07-12-2004 09:55 AM
A7V8X-MX IDE errors klinux QnA (read only) 4 22-11-2004 11:08 PM
overclocking on A7V8X-MX-SE?? Choto Cheeta QnA (read only) 18 07-10-2004 04:08 PM
