Old 13-04-2007, 10:37 PM   #1 (permalink)
Gaurav's Avatar
Default what to do dual channel or single
I purchased 512MB Kingston DDRII ram 667mhz , I was having a 512 MB Stick earlier that too of kingston DDRII 667 MHz. But both of them have different chips, the new one is having Hynix chip and the older one has s64320.
I have installed both of them in same color slot of My mainboard, and now they are showing as dual channel memory(in CPU-z). Is it safe to have installed the two ram in same color slot? pleas throw some light.....
Gaurav is offline
Old 14-04-2007, 08:34 AM   #2 (permalink)
deathvirus_me's Avatar
Default Re: what to do dual channel or single
For dual channel u need to have similar modules i.e. the same number of memory banks , even from diff. manufacturers will do ...
Its good that they are detected in dual-channel mode .. u need not worry .. keep using ur computer as u do in general .. If u get random BSOD's or sudden restart then report back ..
As about which slot to use .. it differs for most mobo .. some use consecutive slot for dual-channel config .. and some use alternate slots ... just depend of the mobo manufacturer ....
deathvirus_me is offline
Old 15-04-2007, 12:36 AM   #3 (permalink)
Gaurav's Avatar
thanks, I have let them as it is. well the system is working quite fast.
Gaurav is offline
Dual Channel RAM (Second Set) godblessedson QnA (read only) 6 06-03-2009 11:55 PM
Dual Channel Or Single Channel karthik55859 Hardware Q&A 6 01-08-2006 12:36 PM
Dual Channel??? joy_chak Hardware Q&A 24 18-01-2006 12:09 PM
Dual Channel d QnA (read only) 3 16-12-2005 07:40 PM
Dual Channel RAM goobimama QnA (read only) 4 03-01-2005 08:29 AM
