Old 13-04-2007, 06:05 AM   #1 (permalink)
Default need help to find mobo?
pls. suggest mobo with below features,
1. must have AGP 8x, SATA port, on-board VGA
2. atleast support P4, P4D proccy with HT(if C2D it's better)
3. atleast DDR400(if DDR2 it's better)
bhoolkumehul is offline
Old 13-04-2007, 09:44 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: need help to find mobo?
U didnt write your budget...
also, i dont think there is any Motherboard, which support C2D and Has AGP 8x
then again. i may be wrong, waiting for others to reply...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 13-04-2007, 10:08 AM   #3 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
AGP is old standard....no longer continued in new Boards. As for Onboard Graphics and C2D...here are few
1. ASUS P5B-VM
2. Intel DG965WH
3. Intel DG965RY
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 14-04-2007, 06:13 AM   #4 (permalink)
what's price of these mobos?
Old 14-04-2007, 11:05 AM   #5 (permalink)
Host4Cheap.org
http://www.theitwares.com/
Old 14-04-2007, 01:22 PM   #6 (permalink)
gsmsikar's Avatar
this is a good mobo for you, but it does not have AGP
ASUS P5VDC-MX
http://www.asus.com/products4.aspx?l...14&modelmenu=1
gsmsikar is offline
Old 14-04-2007, 01:39 PM   #7 (permalink)
NP : Crysis
xbonez's Avatar
i wonder why u would want an agp slot when the norm today is pci-e
xbonez is offline
Old 14-04-2007, 05:09 PM   #8 (permalink)
napster007's Avatar
the one ur looking for is intel 915gl. it has agp 8x and also pci-e. it comes for no more than 3k. i have the same one and it also has sata and ata. it supports memory upto 400mhz.
napster007 is offline
Old 15-04-2007, 12:19 PM   #9 (permalink)
NP : Crysis
xbonez's Avatar
the intel 915gl will not support C2D so it would be better to invest a little more and go in for a mobo that supports C2D. however, i don't think u'll find any such mobo that also has an agp slot. if an agp slot is more imp for u than C2D support, go for the intel915gl
xbonez is offline
cant find BIOS for my MoBo! mario_pant Hardware Q&A 1 12-06-2006 07:15 PM
strange mobo!!!can't find AGP slot Help guyz! techmax CPU / Motherboards 10 23-09-2005 04:15 PM
MSI mobo or INTEL mobo pls. help karthik316_2003 CPU / Motherboards 10 29-05-2005 03:29 PM
how to find bharathbala2003 QnA (read only) 8 20-02-2005 01:20 AM
