Old 12-04-2007, 11:00 PM   #1 (permalink)
Default Hi can some1 help me out
Hi all
I just wanted a piece of help from you all
i got nvedia graphics card GeForce 6500
i want to install it can n e 1 guide me for this i would b very thnkful to him
i was almost done with the installation but something i had missed out so have removed n kept aside so if n e 1 wish to help me in this i would b thnkful to that person
Regards
Ankit
anksin is offline
Old 12-04-2007, 11:10 PM   #2 (permalink)
Default Re: Hi can some1 help me out
Ankit what error did u have while installing can u be more detailed so someone can help u out.
ranjan2001 is offline
Old 12-04-2007, 11:29 PM   #3 (permalink)
assasin's Avatar
the installation guide is give in the User Manual provided with gfx card packaging.read it carefully,sud solve ur prob
assasin is offline
Old 13-04-2007, 10:17 AM   #4 (permalink)
theres no error as such but 1 of my frnd told to disable the display which is onboard how to do so
i disabled the onboard diplay n restart the machine with nvidia inserted the display is not good enought somethng weird
hope this can help u solve my prob
anksin is offline
Old 13-04-2007, 11:28 AM   #5 (permalink)
OH then its not a problem
once u disable the onboard insert the card & boot in then install the drivers for ur card then once done go to desktop
Right click in blank area>properties> this will open Display properties>settings> here u will see the resolution,
U need to set at least 1024x786 & color quality at 32bit (highest)
This should solve ur problem, actually its not a problem, just that u need to set the setting.
Old 13-04-2007, 03:52 PM   #6 (permalink)
exactly i thought so there might b some setting to b done i will try the same n give a reply
u guys r so help fuil
thanks alot
anksin is offline
Old 15-04-2007, 01:23 PM   #7 (permalink)
hi ranjan
i tried as u said disable the on board display n then install the new card but i gues theres a on board display n graphics card conflict i have got nvedia ge force 6500 card n i have asus motherboard with amd procesor n 512 mb ram
can u help me come out of this conflict prob
thnx again in adv
anksin is offline
Old 15-04-2007, 04:21 PM   #8 (permalink)
Can u be more detailed & tell step by step what u did?
It should be simple to disable the card reboot & then install the new card & its driver.
Some1 give me Cheats for ROADRUSH 1.8.0? rakeshishere Gamerz 4 24-07-2006 09:53 PM
can some1 give fundas of torrent/peer/seeder/leecher/bitcomet/bitcomet tracker etc?? tango_cash Software Q&A 3 05-07-2006 07:16 PM
My ISP saying I hacked some1 casanova Software Q&A 48 03-06-2006 06:57 PM
