Old 13-04-2007, 11:36 PM   #31 (permalink)
Learner
Kniwor's Avatar
Default Re: Asus P5B DLX vs P5N-E SLi
Originally Posted by assasin
shall i be able to get a E4400 or E6320 by mid-May or early June???
only prob in P5N-E SLI that i find is the absence of a Southbridge heatsink
do u wanna say that 8600 sux???if yes then why???
as far as ATI is concerned theres not much news about their release dates
basically...YES
Kniwor is offline
Old 14-04-2007, 08:36 AM   #32 (permalink)
assasin's Avatar
ok.'my friend and i hav decided to buy:
C2D E4400
Asus P5B DLX
2*1GB DDR2 667 Dual Channel
DX10 gfx card.
the main reason behind not choosing the P5N-E SLI is that i've read in many reviews that the mobo has 'FSB Holes'bet 400-450 fsb.aslo it doesnt hav a áll solid state capacitor' design and tends to run hotter than 965.
if u guys find any flaws in this config then plz suggest.....
assasin is offline
Old 14-04-2007, 10:35 AM   #33 (permalink)
darklord's Avatar
C2D E4400
Asus P5B DLX
DX10 gfx card.
E4400 available ?
doesnt matter if its 667 or 533,get whatever is cheaper.Remember,C2D is not bandwidth hungry
P5B Deluxe ? Why ?? That thing costs 12k or so,if you can afford that why not P5N32-E ? I just dont understand why you ignore it so much ?
Also P5B Dlx is not Solid Caps all over.....
Its a known fact that NV chipsets run warmer.Its there since NF4 chipsets
Upto you man.....choose for yourself.
darklord is offline
Old 15-04-2007, 11:59 PM   #34 (permalink)
assasin's Avatar
i'm just waitin for Intel to cut prices.
afaik P5B DLX (non wifi version) costs bout 10.5k.
as of now E4400 is not available,but i xpect it to get it by mid-may or early June.
assasin is offline
Old 16-04-2007, 12:29 AM   #35 (permalink)
deathvirus_me's Avatar
Well , with the E4400 , and using a 1:1 ratio , the E4400 will hit 3 GHz even on ddr2-533 RAM ... That'll be an awesome buy .. and with ddr2-533 modules , u can really push some tight latencies ... and even with value RAM's one could manage 3-3-3-8 i think ..
deathvirus_me is offline
asus a8n-e or a8n-vm? melvinchacko Hardware Q&A 14 05-08-2006 12:54 AM
Asus K8n-vm nishant_nms Hardware Q&A 1 25-07-2006 11:55 PM
ASUS 5900Ultra or XFX 5900 ultra or ASUS 6600 or XFX 6600 ?? rachitboom2 QnA (read only) 1 07-03-2005 02:32 PM
ASUS 5900Ultra or XFX 5900 ultra or ASUS 6600 or XFX 6600!!! rachitboom2 QnA (read only) 1 06-03-2005 04:05 PM
Does anyone use ASUS K8N.... rollcage QnA (read only) 13 01-02-2005 01:00 AM
