Old 12-04-2007, 12:32 AM   #1 (permalink)
royal's Avatar
Unhappy I need a multipin laptop power connector
Ok this is going to sound weird. The laptop that I use at office (and bring home to watch movies ) has to be connected to a "dock". This "dock" has all the necessary ports (for e.g. power/USB/LAN etc) and the corresponding cables/devices are attached to it. These things could have been attached to the laptop itself, but the funda is that once they are connected to the "dock" , all I have to do is to attach the laptop to the "dock" before beginning work. In this way, I dont have to connect/take out the cables everyday when I come back home.
I think I have made myself clear ... If not , here's a similar product
Now the power adapter is connected to the "dock" and it doesn't fit into the power port of the laptop itself , which is of a different size (one is 2.1 mm and 2.5mm).
Here's a sample pic
So all I need to know is how to interchange between the two ?
If what I said appeared hebrew to you, here's what I need
royal is offline
Old 12-04-2007, 07:31 PM   #2 (permalink)
Laptoping
Sourabh's Avatar
Default Re: I need a multipin laptop power connector
Yes, you have made it very clear. I have no idea where to get those individual connectors, but laptop power adaptor of 120W rating with all those connectors is available for 2,000 Rs. So, if you manage to get one of those adaptors, you can manage to power the laptop at home (and in office, just in case)
So, well this is the 'expensive' solution. I don't even know why I am posting this, you can easily get a separate adaptor for the laptop for a few hundreds less. But, the universal power adaptor can be a nice one time solution. If you know what I mean
Sourabh is offline
Old 12-04-2007, 11:23 PM   #3 (permalink)
royal's Avatar
Smile Re: I need a multipin laptop power connector
Thanks for your reply. I shall be moving to UK next month and there I can get a Barrel adaptor for less than a pound. I just wanted to know whether those are available locally as well.
However what you suggested is also valid. Maybe I'll buy one sometime in future.
royal is offline
Help! Need Graphics card Power Connector! goobimama Graphic cards 8 17-02-2007 07:36 AM
Balancing battery and power supply on laptop sakumar79 Laptops and Netbooks 5 11-05-2006 07:00 PM
IDE Connector Issue.. dreams Hardware Q&A 4 28-01-2006 03:25 PM
USB Connector In P3 sainit Peripherals 3 09-07-2005 02:20 PM
Laptop Power Adapter for Indian outlets Nemesis QnA (read only) 4 19-12-2004 05:24 AM
