| Forum |
#1 (permalink) |
Plz help !!! what to do next ???? |
#2 (permalink) |
it might be the boot error beeping, reset the bios if u know how to do it & check for some loose connection .
Check ram, graphic card, etc & if its old comp then ensure that the haetsink is clear of dust & the power supply is good enough to supply proper current to the system.
E6300@3.304Ghz,P5B-Dlx Wifi, 4GB Transcend DDR2 800Mhz, XFX 7600GT,Lenovo 20"Widescreen LCD, Seagate SATA2 HDD 1.5TBx2,Sony DVDRW,Creative 4.1 speakers,APC UPS 800VA,Logitech wireless mouse. |
#3 (permalink) |
ToTheBeatOfUrHeart
I had a similar problem.These type of problems occur when the ram modules r faulty or mismatch or have different artitecture.Go get ur ram modules checked one at a time on another computer.
Mobo - P5N32-E SLI,P5N-E SLI|GFX - 2x8800GTS,8800GT|Processor - E6550,E6600|PSU - CM EP 600,HX620W|Physics - 2x8600GT |
#4 (permalink) |
TeCh Blogger : Gtechinfo
the above post frm shyamno is for my computer , i was facing the problem yest'r day, i told him to post here bec, my comp was not starting on that time, thn after some time whn I start my comp it suddenly started normally and till thn it is ok, it happened once in last wk, ie not starting thn again it get normal, is it due to fault in motherboard or ram or OS, or it is a case of lose connection, my comp is about 1.5 yr old.
#6 (permalink) | |
by the way if it is mobo problem thn howmuch time will intel take to replace it, i stay in kolkata and how will i send the mobo there. my mobo is intel D101GGC, arround 1yr old Last edited by gau_pppu; 13-04-2007 at 09:36 AM. Reason: Automerged Doublepost |
#7 (permalink) |
Search for Adventure
do some job - plug out then in all the connection on board (i.e hdd,smps,ram) then start the comp, if it make any noise then try to test with another ram, if it won't work with other ram then surely it's ur mobo.
Nobody is Perfect. I am "Nobody" |
#8 (permalink) | |
#9 (permalink) |
i too am facing a shutdown prob. ever since i installed win server2k3, many time when i try to shutdown, it simply restarts rather than shutdown. i've installed the lastest sp2 and also the security updates
#10 (permalink) | |
If not re-plug ur parts with mobo & try, if won't work then try with another RAM. still I think it's the mobo prob. all the best
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Help...Computer is restarting while installing Windows XP... | debaisaindian | Hardware Q&A | 11 | 11-02-2007 09:54 PM |
| computer randomly restarts | izzikio_rage | QnA (read only) | 9 | 24-10-2006 07:15 PM |
| Computer restarting...:( | nilesh4u | QnA (read only) | 13 | 30-03-2006 11:44 PM |
| System restarts randomly. | Kannan | Hardware Q&A | 3 | 03-01-2006 03:30 AM |
| computer restarting automatically | dittualex | QnA (read only) | 1 | 14-11-2005 12:44 PM |
