| Forum |
#1 (permalink) |
I have 2 partitions already (i.e- "C: 106GB " & " D: 6GB ") , but i want to make some more partitions of "C:" drive. i have windows in C: drive. i want 3 partitions of " 16GB , 45GB, 45GB ". Can ne1 plz help me. |
#2 (permalink) |
ThE oNE & ONlY ??
well download a software called partition magic or search for other partitioning softwares available on the net... you can use windows in built tool (in xp, vista) but since you want to partition your c drive Im assuming you want to do it non destructively ie without losing data...
R.I.P 2pac, Biggie & Proof Holla atcha' wherever you are !!! |
#3 (permalink) |
a_g = JPKN
i suspect you're having a HP desktop PC
if yes then read this - [Tutorial] Creating Partitions in HP Pavilion Desktops & Laptops
★----------�----------★ _ ★----------�----------★ |
#7 (permalink) |
Actually i want to switch from Vista to XP.
There are lots of problems i m facing. Softwares dont get installed properly due to incompatibility. Since i have 120GB HDD. Vista in C: (106GB) and recovery in D: (5.22GB). I have hp laptop. And want to make partitions of C: as i told above. Now i think its much more clearer to tell me the solution. I want to delete that recovery. Will that recovery be of any use in the future ?? Will it be usefull if i switch back to vista again?? plz help me...... one more thing, i have installed nero 7 premium demo but due to compatibility issue it didnt get installed properly. and now when i m trying to uninstall, it doesnt get removed. so plz help me .... |
#8 (permalink) |
Download and install HDD partition software. I recommend Paragon Partition Manager.
>First of all disable System restore and disable "Hibernation" mode. Restart PC. >Since you want to make 16GB primary partition in C drive, I advice you to remove all the data exceeding 16GB to a external media. Finally you should have data on C Drive less than 16GB. For instance keep the CD drive to 14GB. > Now open Paragon Partition Manager and create a CD Bootable Partition tool. Most of the popular partition tools do have this option. >Restart PC with CD in the drive and keep pressing F12 Key. Now PC will boot via CD. >Select C Drive and partition it to required sizes. If you face any problems, do revert back.
Kiran Kumar R |
#9 (permalink) |
now tell me about formatting...
that D: partition is of any use. If i install win XP it will not be used further, right?? if i simply delete it from going into COMPUTER->MANAGE->DISK MANAGEMENT.. will it get removed.... will it get removed after installing XP by using same method.. |
#10 (permalink) |
a_g = JPKN
i dont know whether you're using a HP desktop, but if you Delete/Format that "Recovery Partition", then you'll have loads of problem when you're XP installation goes crazy (virus problem), coz then you may have to use Recovery Disks to install XP again, which in the process will wipe all data on HDD including the paritions you create.
btw its just 6 GB partition, keep it, you wont have any problems with it. delete it only IF you want to install Vista or another XP.
#11 (permalink) | |
Kiran Kumar R |
#12 (permalink) |
thanx for ur replies ...
now when i try to install xp with a bootable cd, at the point of selecting the option to enter the XP setup, it shows a mesage "setup didnt find any hard disk installed on this system" and then it restarts the system. can ne1 tell me about the problem?? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Install same Win XP OS on two different partitions! | patkim | Software Q&A | 7 | 22-01-2007 03:03 AM |
| Cannot create Partitions | Nav11aug | Software Q&A | 5 | 18-01-2007 04:39 PM |
| how do i merge partitions? | jz2linkinpark | QnA (read only) | 9 | 12-09-2006 02:16 PM |
| Help me to merge my two partitions! | technovice | QnA (read only) | 4 | 14-05-2005 04:43 PM |
| abt partitions and 7610 | ranjodh | QnA (read only) | 8 | 12-04-2005 06:24 AM |
