| Forum |
#1 (permalink) |
By Regards, Amey. |
#2 (permalink) | |
Thats all i can think of right now. |
#3 (permalink) | |
OK but whts the solution for it ? i cant even burn any dvd coz it cant read blank dvd also. I tried every company ie sony,moserbaer,imation, and also cheap quality media.
Also the writer can read as well as write cds. Quote:
By Regards, Amey. |
#4 (permalink) | |
#7 (permalink) | |
check the option (verify the CD after burning ) and try .... post the result.... |
#9 (permalink) | ||
You say the Writer just doesn't read any blanks OR old written DVDs (burned using the very burner) ? But it does recognise CHIP/Digit DVDs.. Seems the Writer's days are numbered .. If the Writer's in its warranty period, try RMAing it. |
#10 (permalink) |
ToTheBeatOfUrHeart
Try ramming ur laptop if it's under warrenty.Then get it fixed or get a replacement.Cause that's what i did when i burnt my graphics card(i Overclocked it).Yet they replaced it.
Mobo - P5N32-E SLI,P5N-E SLI|GFX - 2x8800GTS,8800GT|Processor - E6550,E6600|PSU - CM EP 600,HX620W|Physics - 2x8600GT |
#11 (permalink) | |
I also upgraded the firmware, but no use. Also its out of warranty, so if i go to service center they will charge for it.
Lets see, or the last option is to go to the service center.
By Regards, Amey. |
#12 (permalink) | |
#13 (permalink) |
Hi,
Don't pay money yet, first of all DVD-R are pretty chip and it is better to buy a new one then pay $50 on an old one which might not work again. Second I had some problem with my CD-R and I asked in a free tech support. They gave me a solution that work for my problem (Updated the driver for xp). Here is the page for DVD burners troubleshooting support I hope you'll find a solution Marcella |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| DVD writer problem... | shyamno | Hardware Q&A | 8 | 03-04-2007 04:54 PM |
| Problem With My DVD Writer ??? | navino87 | Hardware Q&A | 2 | 05-01-2007 09:58 PM |
| DVD Writer Problem | sagargv | QnA (read only) | 1 | 20-08-2006 07:42 PM |
| CD Writer problem | h_kunte | Hardware Q&A | 3 | 23-02-2006 11:21 PM |
| DVD Writer Problem | siddhesh | QnA (read only) | 12 | 13-11-2004 09:13 PM |
