Old 09-04-2007, 08:19 PM   #1 (permalink)
Exclamation Mobo help
Yo guys, I'm planning to buy a new cpu as my old cpu is f***ed up. As I'm on a tight budget I've decided to go with the Core 2 Duo E6300 1.86Ghz, 2GB DDR2 533Mhz RAM, 160GB HDD, Nvidia8800 GTS 640MB & ASUS P5LD2 Mobo. But I want to know if the ASUS P5LD2 Mobo will support the 8800GTS card. If not could you plz suggest another mobo but plz remember I'm on a tight budget.
SFDeltaUnit is offline
Old 10-04-2007, 05:21 AM   #2 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Default Re: Mobo help
Wrong section dude it should be in the Q&A section
Harvik780 is offline
Old 10-04-2007, 05:32 AM   #3 (permalink)
18 Till I Die............
It belongs to 'Hardware Troubleshooting' section.
http://www.bash.org/?258908
mehulved is offline
Old 10-04-2007, 05:47 AM   #4 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Well he's asking a question.
Old 10-04-2007, 06:02 AM   #5 (permalink)
on Hardware
mehulved is offline
Old 10-04-2007, 07:20 AM   #6 (permalink)
Default New CPU help.
I'm planning to buy a new cpu with Core2Duo E6300, 2GB DDR2 533Mhz RAM, 160GB HDD, Nvidia8800 GTS 640MB & ASUS P5LD2 Mobo. I want to know if this mobo can support this graphics card. If not plz suggest another mobo.
Old 10-04-2007, 07:42 AM   #7 (permalink)
Thread locked as the member has been banned for abusive PM's.
mehulved is offline
What do u think of this MOBO ? ? ? tiblu Hardware Q&A 5 10-05-2006 09:42 PM
MSI mobo or INTEL mobo pls. help karthik316_2003 CPU / Motherboards 10 29-05-2005 03:29 PM
Pls. Help => Which MOBO ??? rachitboom2 CPU / Motherboards 11 23-03-2005 04:34 PM
