09-04-2007, 05:08 PM
pc stopped working
my config AMD sempron 2400; gigabyte-400VM-RZ board with 256 DDR ram.
The PC stopped working inbetween. The monitor got switched off. The red led was glowing for some time. The PC as restarted, but the monitor did'n't turn on. The beep sound on starting of the pc didn't come. Is it RAM problem? The RAM was cleaned and put back. No use. please help
09-04-2007, 05:17 PM
Re: pc stopped working
Is the led on monitor glowing? If not , check monitor power cable.
If the led is glowing on monitor and CPU's light is also on after switching on, then try to reconnect the video cable after stretching it a little(not too much).
a_g = JPKN
try putting other's (friends) RAM.
ASUS K53SV SX520D + BF3
09-04-2007, 06:01 PM
Search for Adventure
chked ur smps?
Nobody is Perfect. I am "Nobody"
09-04-2007, 06:55 PM
SMPS chk.
KDE on ArchLinux
10-04-2007, 02:14 PM
the monitor is ok. wheni disconnect the pc cable it is switching on . The ram was changed. but no effect. The beep sound on starting the PC is not coming. No other beeps (indicating RAM failure)e coming. The maintenance person is suggesting that the mother board may be faulty. Mine is gigabyte 7vm400-RZ. Please advice
10-04-2007, 06:03 PM
nah. these technicians say something that will grab you money. My technician says now P3 cant be used for anything. I am using linux on P3 and it works as an express.  Mobo may not be faulty. First thing-- Buy a multimeter/continuity checker or borrow one from someone. Then remove the monitor's supply(PWR) from the back of the SMPS. Then remove the SMPS input plug from the main socket(not behind the SMPS) and keep the two ends of the continuity checker on the two small pins i.e. phase & neutral on the plug, not the mains; see if the light glows if a continuity checker or the meter moves(in continuity mode) to the right. If the light does not glow or the meter doesn't move then probably; the SMPS is dead. Try replacing the SMPS.  Try and Report.
KDE on ArchLinux
10-04-2007, 06:53 PM
Chk ur smps, unknown is wright, plug out ur cd rom floppy etc only mo/bo - HDD attach & switch on power without monitor, if the beep comes then may be the cdrom is fused, if beep don't come the ur smps is faulty
10-04-2007, 07:01 PM
U did not understand wht i said. I said check the SMPS input. The principle based on physics is
Originally Posted by principle based on physics
when any electric object works, current flows from Phase to Neutral. When there is any break in the circuit like a burnt Transformer, a blown capacitor, etc. current will NOT flow from Phase to Neutral. So any multimeter if shows you continuity, the object is working.
But he must disconnect the SMPS from the MOBO, CDROM and HDD b4 doing that.
KDE on ArchLinux
10-04-2007, 09:13 PM
first of all make sure to find out all the voltages from the smps are correct,, also check the ram slots,, and processor fitments perfectly,, then later try checking the video adapter,, if all these are right good,, then u have to check the processor and also the mother board,,
since one of my AMD system caused the same problem, and finally the response was problem in processor.
lets find out all these checks.
3d Graphics Animator, //\\ Senior level team Leader
Life is so deep,, that if we try to see in it, we may fall ourselves
12-04-2007, 05:19 PM
the smps is ok. my monitor powersupply is from smps.monitor is getting switched on and the PC fans are also switching on along with both CD rom and DVD writer. The keyboard lights( caps lock,num lock etc) are not glowing on startup. New ram was put and graphic card also (in friends PC with new SMPS) still the same problem. The start beep is not coming.Please advice.
12-04-2007, 05:27 PM
a_g = JPKN
check the capacitors around the Processor, if its havin rusty top, & swollen, then you know you got a motherboard problem.
replacing them will solve it.
13-04-2007, 01:45 PM
Did you chk the Pwr_Ok voltage of smps??
My new Config: Phenom II X6 1100T + ASUS M5A88M + Palit GTX 260 + 4GB Ram(Corsair Vengeance) + 200 GB(Hitachi) + 500 GB(Seagate) SATA+ 1TB external(Seagate) + Corsair VX550 W Smps.
ACER TravelMate 4740
http://www.flickr.com/photos/adhip_ghosh/
