Old 08-04-2007, 06:06 AM   #1 (permalink)
jayanbhm's Avatar
Default processor over heating????
Dear friends
iam facing a strange problem when ever iam using more than one program at a time (opening two word documents copying files etc) my processor speed will increase to 90-100% and my system became very slow. When i tried to copy files form one drive to another i cannot do any other applications even to open a document it will take nearly 5 minute and my processor is making a very big sound like generator. Suggest me something to eliminate this problem
here is the configuration of my pc
OS Name: Microsoft Windows XP Professional
OS Version: 5.1.2600 Service Pack 2 Build 2600
OS Manufacturer: Microsoft Corporation
OS Configuration: Standalone Workstation
OS Build Type: Uniprocessor Free
ystem Manufacturer: INTEL_
System Model: D915GVWB
System type: 86-based PC
Processor(s): 1 Processor(s) Installed.
01]: x86 Family 15 Model 4 Stepping 1 GenuineIntel 2667 MHZ
Version: INTEL - 516
Windows Directory: C:\WINDOWS
Total Physical Memory: 356 MB
Available Physical Memory: 114 MB
Virtual Memory: Max Size: 2,048 MB
Virtual Memory: Available: 2,008 MB
Virtual Memory: In Use: 40 MB
pentium IV 2.66 GHZ
with thanks
JAYACHANDRAN.C
jayanbhm is offline
Old 08-04-2007, 09:18 AM   #2 (permalink)
assasin's Avatar
Default Re: processor over heating????
it cud be either that DMA is not enabled 4 ur drives or ur pc is infected with some virus.
first check whether DMA is enabled,then check if any particular process/thread is eating very high resources in task manager.if u find any close it and run anti-virus scan.
assasin is offline
Old 10-04-2007, 12:22 AM   #3 (permalink)
mohitgiri's Avatar
open ur processor fan and fit it tightly again.
MOHIT GIRI GOSWAMI
mohitgiri is offline
Old 10-04-2007, 08:29 PM   #4 (permalink)
it looks like whenever you load ur cpu the performance goin down so check your heatsink is installed correctly ,if needed apply some good thermal paste.
srinivasbg is offline
over heating vikram Hardware Q&A 13 17-05-2006 11:12 PM
My HDD is heating above 50 deg cel.Do i need to worry? NagpurDaMunda QnA (read only) 18 28-03-2006 08:13 PM
processor heating problem!!! techmax Hardware Q&A 6 19-10-2005 06:42 PM
OVER HEATING !!!!!!!!!!!!!!!!! navisangha QnA (read only) 12 26-05-2005 09:43 PM
Over Heating problem mako_123 QnA (read only) 10 24-03-2005 11:43 PM
