Old 07-04-2007, 09:33 PM   #1 (permalink)
ankitsagwekar
Posts: n/a
Default help me to built pc
i want to buy pc Budget 35000
i want 1gb ram ddr not ddr2
dule core processor any intel not c2d or amd
good motherboard whit 16x pcie
intel 915 or better chipset (which run vista aero whitout graphis card)and 7.1 audio card (onbord) give me motherboard model number
120gb hdd
2.1 or 5.1 speaker
dvd writer
any think which i forget to mention plz give me information
give me price and brand for above device any advise is welcome
Old 07-04-2007, 10:00 PM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: help me to built pc
What u have said wud be the least future proof new PC.
C2D is really gud if u have the bucks and if u are lil low on budget then X2 also is gud. Buy what u specified is Pentium D, which is just a waste of money. Its low on perfomance and it gets hot quickly.
And DDr2 667 are available for low prices and are way better than DDR-in terms of perfomance and also power consumption.
Get the following config:
AMD Athlon X2 4200+ : 6.1k
Asus M2N MX: 4k
2x512 DDR2 667 transcent: 5k
160GB Seagate SATA2 : 2.5k
Logitech X530 5.1: 5.5k
Liteon 20X DVDRW : 2k
And u didn't memtion monitor, cabby, K/B nd M/S.
17" CRT : 5k
cabby: Zebronics w 400w : 1.3k
K/B nd M/S : 0.8k
if u wanna reduce the price then settle for an Athlon X2 3800+ : 5k
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 07-04-2007, 10:39 PM   #3 (permalink)
ankitsagwekar
Posts: n/a
i want lcd 17''
asus m3n mx is for intel or amd???
Old 08-04-2007, 09:21 AM   #4 (permalink)
assasin's Avatar
Asus M2N-MX is for AMD Socket AM2 proccies.its a good mobo.
assasin is offline
Old 08-04-2007, 01:01 PM   #5 (permalink)
for 35,000 u an get a very good amd config and i think u shld go for that ..the amd x2 is not far behind the c2d ...buying a p4 or a dual core processor would be a serious mistake...and why dont u want ddr2?
the prices of ram have come down! its not that expensive
azad is offline
Old 08-04-2007, 02:20 PM   #6 (permalink)
Super Saiyan
Goten's Avatar
In 35000 u can easily rock ur world.
Go for an AMD.
Peace~~~!
Goten is offline
Old 08-04-2007, 02:31 PM   #7 (permalink)
Google Bot
Pathik's Avatar
ny reasons 4 not getting a c2d or amd config??
Pathik is offline
want to built autopatcher for linux gary4gar Open Source 54 19-02-2007 02:22 PM
RC1 Built 5560 sysfilez Software Q&A 1 20-09-2006 02:27 PM
Lcd With Built In Xp mihirvashist Technology News 5 30-07-2006 10:05 PM
Built ur own pc. rajas700 Tutorials 3 10-09-2005 09:33 AM
I built a new website!! I want some tips. anispace QnA (read only) 2 09-08-2004 02:38 PM
