Old 07-04-2007, 12:55 PM   #1 (permalink)
Thumbs up Motherboard & CPU Bundle - Suggestion Required
Hello Friends,
I want to purchase a PC in near future so i have few quires regarding this. pls help me ...
1> Which motherboard & CPU Combination will give best performance so that i can get 100% from these. CPU Should be core2Duo. My Budget for both M.B. & CPU is around 15000 - 17000.
2> Good Cabinet with around 500W Power Supply.
Thanks
sainit is offline
Old 07-04-2007, 01:15 PM   #2 (permalink)
Default Re: Motherboard & CPU Bundle - Suggestion Required
cabinet - zebronics peace or antibiotic ( both arnd 2500) and a zebronics platinum 500w psu or a zebronics diamond 540w psu
cpu - c2d 1.86 Ghz - arnd 9000 Rs
are u planning to buy/ do u have a graphics card?
u cld use this mobo- asus p5bvm (arnd 7900 Rs). It comes with integrated graphics
azad is offline
Old 08-04-2007, 11:14 AM   #3 (permalink)
Tux Fan
shaunak's Avatar
If you are so adamant on getting C2D now then go for the E6300\6400 which retails at about 9K and the Intel® Desktop Board DG965RY. Its onboard gfx supports the aero interface so unless you are into heavy gaming you will not need a graphic card.
if you could strech your budget [or wait for the prices to fall] the get at least the E6600.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Need Motherboard Suggestion.. dreams CPU / Motherboards 29 08-04-2007 05:02 PM
Nokia 5200 - Suggestion Required utsavhanda Buying Advice 16 04-03-2007 09:53 PM
URGENT!!!Problem with mercury 810 motherboard....solution required spidyweb Hardware Q&A 1 14-09-2006 07:29 PM
new pc -suggestion required mukund1224 QnA (read only) 5 23-02-2005 04:39 PM
motherboard help required pls!! prankzter CPU / Motherboards 2 01-02-2005 11:50 AM
