Old 07-04-2007, 11:52 AM   #1 (permalink)
vwad's Avatar
Location: Why ? Are you coming for dinner ? Pls. Don't.
Default TV Capture Card for Recording from VCR !!
Hello,
I need ur help friends
I want to buy a Video Capture Device like Tuners but I want to mainly record from my VCR since I plan to dispose off all my old VHSs but want to save them to my HD before I do so.
I want USB box/card/cord for the same.
I dont want PCI ones.
I mainly need to have strong Composite Input Ports on my capture device so that I can connect my VCR through only Composite ports.
I have Sharp VCR with one Composite Output each for Audio & Video. It is like the ones which are connected by RCA cables.
I want to have same input holders on my capture device.
My budget is around 2500-3500 Rupees
Can anybody suggest me a good buy ?
An Old Lady Died In Her Childhood.
vwad is offline
Old 09-04-2007, 08:40 AM   #2 (permalink)
vwad's Avatar
Default Re: TV Capture Card for Recording from VCR !!
any suggestions ??
vwad is offline
Old 09-04-2007, 09:06 AM   #3 (permalink)
assasin's Avatar
just hav a look at Digit issue for this month.theres a shoot-out on tuner/capture cards.
assasin is offline
Old 09-04-2007, 08:30 PM   #4 (permalink)
Laptoping
Sourabh's Avatar
For the records, any USB tv-tuner would do. The frame rate drops for recording from composite input are negligible. I hope you do know that USB ones are expensive. Compro and Pixelview solutions cost 3.5-4k whereas Pinnacle's usb tvtuner costs 5k. Refer this month's digit for exact prices.
Sourabh is offline
The Best possible TV / Video Capture Card ..:: Free Radical ::.. Hardware Q&A 4 05-03-2007 12:24 AM
graphic card or T.V card for video capture on harddish jagdish18 Software Q&A 2 08-12-2005 02:31 AM
Help me with My Capture Card tirthasanyal QnA (read only) 1 16-03-2005 11:55 AM
Help me with My Capture Card tirthasanyal QnA (read only) 1 13-03-2005 03:43 PM
which one is the best tv capture card??? beaditya QnA (read only) 9 31-12-2004 11:06 PM
