No GFX. what all changes i have to make to this configration to run vista Smoothly. My motherboard is quite Basic one No PCI EXPRESS,No DDR2 support.i am not into gaming .Just want to upgrade to Vista.Thanx in advance.
vista will require minimum 512MB ram and as you have inbuilded graphic card, it will have some shared memory so you will not able to install vista.
borrow RAM from friend and increase it above 512M.B. install vista-remove borrowed ram and put back your 512MB RAM. vista will run on it .
for smootly running vista atleast 1GB ram is require and if you want AERO feature you need a graphic card with 128M.B. RAM
you never know what you can do until you try
Vista Does nt have much to far apart from the interface and the appeal.....
So My suggestion for u is
instead of installin vista go for vista transformation pack which makes ur xp look like vista ....it changes everything from icons to task bar....
But if u still wanna go with vista ...go ahead and install it ...Ur pc is descent enought to run vista..BUt all the fancy frills will be turned off
The 3d user interface will be turned
so dude go for vtp6 instead of goin for vista
i've used the same mobo with Vista both with a 6200 256MB 8x AGP card and without it,and performance is not that smooth without a agp card.
so if u wanna use Vista,better buy urself more RAM and a AGP card.
Add another 512 stick and increase gfx shared memory bfrom BIOS..... preferably add a gfx card (256)... That should be enough for Vista to run smoothly......
Hey friend the only thing you have to upgrade is to upgrade your Ram to atleast 1 Gb as it is recommended by Microsoft. Moreover buy a new motherboard as this one is backword without DDR2 support no PCI-e slot.
thanx for your replies guys. DDR1 ram prices are much higher than DDR2.with Future prospective its better to go for DDR2 But My motherboard Doesnt support DDR2.where can i get 754 socket motherboard as its not available at lamington road just called dealer said 754 has been closed.
