Old 06-04-2007, 08:20 PM   #1 (permalink)
Default Ups?
i have a 500VA APC ups. but the problem is that it is continuously giving the beep sound and no power comes from it to the monitor or smps
whats the problem ?
thankx in advance
rounit is offline
Old 06-04-2007, 10:17 PM   #2 (permalink)
Default Re: Ups?
i guess the battery is down..and you will probably have to replace it
azad is offline
Old 06-04-2007, 10:45 PM   #3 (permalink)
Default Re: Ups?
First see whether it is connected to mains and the AC switch is on. Then secondly see whether the relay needs reset. Then whether the mains voltage is above or below the cut off limits.
(BTW nowadays from evening I am having > 145 V, but my Emerson-Liebert handles it without any problem.)
V.Prem Kumar
janitha is offline
