Hello all...
I have 2 SATA Hard Disks on my machine. (I boot from the master disk). I also have a DVD-RW & a DVD ROM on my system. (The DVD-RW is master.)
I brought a friend's Hard Disk home (It is a
Ultra-ATA disk), to format & re-install Win XP on it. To connect it, I removed the IDE cable of my DVD ROM & put it in the HDD.
My problem is as follows:
1. The Ultra-ATA disk fails to get detected. Am I going wrong with the connections??
Could anyone please explain to me the necessary jumper settings that I need to modify, so that I get the following results on my system:
1. My booting SATA HDD should continue to remain as master.
2. My secondary SATA HDD should act as slave.
3. The friend's HDD should get connected & should WORK.
4. I dont mind disconnecting my DVD ROM drive. I just need the master DVD-RW to I re-install windows XP on the friend's HDD.
In short, I want to know, how to make the following connections: (Jumper settings)
1. Disk-1 (SATA) : Master.
2. Disk-2 (SATA) : Slave
3. Disk-3 (Ultra ATA) : IT SHOULD WORK
The bottom line is, that I want to connect ALL THE THREE drives simultaneously.
This is a bit urgent. PLEASE reply ASAP. Please feel free to ask, if you can't fully understand what my query is. Eagerly looking for replies...
Thanks a lot in advance...
-HK.
