hii,..i'm new to here and also to computers...
i have an 80GB HDD..and
i have C:[20GB] as my default primary partition...but after some time some space say 10GB was taken though no files was stored there...so i tried to format it but..it says partition is not allowed to format...currently i've installed my XP in f: drive...and there is nothing in my c: drive but still showing 9GB as occupied...i want to format it...fully..
plz help me!!
Re: urgent!!how to format the primary partition!!?
i say format everything.. & start afresh... C should b where the OS b installed.. I hate systems which have otherwise.
Try to format in DOS mode or as S18000rpm said to. Or u can try deleting any file/formatting by using any live cd available online.
BOOT.ini
ntdetect.com
ntldr
This 3 files are in C: that help in dual booting. this files are needed for booting of Windows Xp in your F: .if you formated your c: drive this files will get deleted and you will not able to boot your winXp
use bootable winXp cd and formate c:
then again
use winxp bootable cd and select recovery console. in command prompt type "fixboot" -to make new files.
you never know what you can do until you try
