Old 06-04-2007, 09:22 AM   #1 (permalink)
Default Saru ne sastu Comp
I am planning to buy this as a cheap Comp basically to run Photoshop and graphic applications - Mobo - msi rs 482 ild & CPU AMD 3500+ with my older ATA HDD and 1GB DRR1 Ram
would it serve the purpose?
scamper is offline
Old 06-04-2007, 11:31 AM   #2 (permalink)
ECE0105's Avatar
Default Re: Saru ne sastu Comp
That wud be good enuf for Photoshop and most graphic apps I guess...
But AMD 3500+ is compatible with only DDR2 RAM AFAIK.
I recommend changing the HDD though.
Some of the happiest people in the world do NOT have Everything... They just make the Best of Everything life brings their way... So, Stay HaPpY.... Smile Always.... :-)
ECE0105 is offline
Old 06-04-2007, 11:55 AM   #3 (permalink)
dOm1naTOr's Avatar
@ECE0105
the older 939 socket proccy supports only DDR. Its todays 3500+ [AM2] that supports only DDr2.
If u are going for that config, then this wud be better
Asus M2N MX: 4k
AMD X2 3600+ : 5k
1GB DDR2 in dual ch:4.5k
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 06-04-2007, 12:51 PM   #4 (permalink)
harikatt's Avatar
yes its good very fine,, for basic phtoshop and graphic applications
3d Graphics Animator, //\\ Senior level team Leader
Life is so deep,, that if we try to see in it, we may fall ourselves
harikatt is offline
H'to conekt Off Comp with Home Comp abhijitroy QnA (read only) 2 22-01-2007 10:53 PM
New comp for 50-60 K Blended Pain Hardware Q&A 6 19-01-2007 11:17 PM
gonna buy a new comp...plz help BLITZ~KRIEG! QnA (read only) 5 01-09-2005 03:40 PM
need for comp. anubhavsinha11 QnA (read only) 2 18-08-2005 04:14 PM
New cd rom in old comp vasanth_12345 QnA (read only) 14 02-06-2005 05:29 PM
