Old 06-04-2007, 07:58 AM   #1 (permalink)
Default webcam woes.... can anyone help???
recently i came up with a need for my webcam to be mobile. so i tried an USB extension cable of length 5 meters. i tried two different cables but neither of them worked. one gave an error of unrecognized USB device, while the other said that the attached USB device can function at higher speeds. also in the second case the webcam was detected but i could not use it. is there any way to work around it? i'm even willing to go for an wireless webcam if it is available. can you please give the details for such webcam?
harshaz is offline
Old 06-04-2007, 08:22 AM   #2 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: webcam woes.... can anyone help???
I had used 4 extension cables connected end to end to form a 8 metre long cable with this camera from Quantum
There were some initial problems as the supply went weak at such lengths, but after changing the cables, everything became Ok
Nokia N86 8MP
Lucky_star is offline
Old 06-04-2007, 12:13 PM   #3 (permalink)
I guess you need a powered usb hub to which u need to connect the usb extension cable so that it can work with the camera.
ranjan2001 is offline
Old 06-04-2007, 12:14 PM   #4 (permalink)
harikatt's Avatar
Red face Re: webcam woes.... can anyone help???
is the OS win2k or winxp,, it depends,, also may be in some cases the drivers are needed.. for exact model detection.. also u have to make sure the cable working
3d Graphics Animator, //\\ Senior level team Leader
Life is so deep,, that if we try to see in it, we may fall ourselves
harikatt is offline
HELP! WEBCAM! chillnow QnA (read only) 3 12-09-2007 08:44 PM
which webcam to buy? ssk_the_gr8 Hardware Q&A 14 21-12-2006 04:18 PM
Which Webcam is the BEST ? c()rrupt QnA (read only) 7 25-10-2005 11:41 PM
No WebCam !!! vishal QnA (read only) 7 25-10-2004 04:23 PM
