Old 06-04-2007, 12:26 AM   #1 (permalink)
786
RajU
786's Avatar
Question Is dual channel memory=DDR2?
I AM CONFUSED...
can any one explain that, is dual channel memory is what we call DDR2?
If no then what is dual channel memory?
786 is offline
Old 06-04-2007, 12:45 AM   #2 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
Default Re: Is dual channel memory=DDR2?
ya ddr2 uses dual channel architecture.. hope this helps
http://en.wikipedia.org/wiki/Dual-channel
http://www.kingston.com/newtech/MKF_...whitepaper.pdf
Blogging @ http://classictutorials.com
the.kaushik is offline
Old 06-04-2007, 01:06 AM   #3 (permalink)
Learner
Kniwor's Avatar
DDR and DDR2 are two memory standards, they could have been name "joey" and "ross" , but dual channel is a way to use all the banks in two memory sticks at a time to boost performance.
both DDR1 and DDR2 can run in dual channel mode.
Kniwor is offline
Old 06-04-2007, 10:34 AM   #4 (permalink)
786
RajU
786's Avatar
Thank u. Can you please suggest me a 2GB dual channel memory DDR2 that is good for gaming and also cost low on price?
786 is offline
Old 06-04-2007, 11:57 AM   #5 (permalink)
dOm1naTOr's Avatar
Get transcent 1GB DDR2 667 * 2 and run in dual ch.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 06-04-2007, 12:04 PM   #6 (permalink)
harikatt's Avatar
i feel,, in mother board a slott will be there naming dual channel memory slot.. which is the main function for dual channel working..
3d Graphics Animator, //\\ Senior level team Leader
Life is so deep,, that if we try to see in it, we may fall ourselves
harikatt is offline
Old 06-04-2007, 12:11 PM   #7 (permalink)
NP : Crysis
xbonez's Avatar
i've got an ASUS A8N vm mobo which supports dual channel mem. i've got 2 512mb 400mhz ram cards slotted in so it is supposed to be running in dual channel config. in dual channel config do the ram cards opertae at a freq greater than 400mhz? if not, what exactly is the advantage of dual channel?
xbonez is offline
Old 06-04-2007, 01:28 PM   #8 (permalink)
Learner
Kniwor's Avatar
The ram still runs at 400Mhz(DDR1) when in dual channel, it's just that when it's in Dual channel, both the sticks are used together, suppose two 512Mb sticks are put in single channel, then there's a 1024Mb ram with 64bit interface, If a file is to be written on ram, it will go to any go to any of them through the 64bit bus, but now if they are in dual channel, it will be 64+64 bit, the file will go partially in both of them, all the banks are considered to be one ram, so it will be 128bit.
not just any two slots in motherboard will run in dual channel, diff manufacturers have diff designs, for some it is adjacent slots, for some alternate, just look at the forum,if you cant find, ask here.
Kniwor is offline
Old 06-04-2007, 09:31 PM   #9 (permalink)
NP : Crysis
xbonez's Avatar
well i have an ASUS A8N-VM nvidia geforce 6100 chipset motherboard. as of now, both the ram cards are slotted in adjacent slots. how do i know if they r runing in dual channel config? i've got everest yltimate edition. will that tell me?
xbonez is offline
Old 06-04-2007, 10:36 PM   #10 (permalink)
install the small free SW cpu-z and check its memory tab. If shown as single channel,, refer your Mobo manual to see where to put the sticks for dual channel. Only take care that the sticks are identical
V.Prem Kumar
janitha is offline
Old 06-04-2007, 11:00 PM   #11 (permalink)
NP : Crysis
xbonez's Avatar
the two ram cards i own are both of 512mb 400mhz however they are from diff companies. i'm not even sure if the latencies match. can i still use them in dual channel?
xbonez is offline
Old 06-04-2007, 11:02 PM   #12 (permalink)
Learner
Kniwor's Avatar
may be.... may be now
Kniwor is offline
Old 07-04-2007, 06:24 AM   #13 (permalink)
I feel that the best thing for you will be to exchange your existing sticks while buying the new 2x1GB to get two identical ones. And nowadays the RAM prices have again come down.
V.Prem Kumar
janitha is offline
Old 07-04-2007, 07:36 PM   #14 (permalink)
NP : Crysis
xbonez's Avatar
how muc would a 1gb 400mhz ram card from a reputed company cost? how much do u think i could get for my 1yr old Transcend 512mb 400mhz ram card?
xbonez is offline
Dual Channel Memory on Intel D101GGC mobo ECE0105 Hardware Q&A 5 25-01-2007 08:02 PM
Dual Channel Memory patkim Hardware Q&A 2 04-01-2007 10:51 PM
Dual Channel Or Single Channel karthik55859 Hardware Q&A 6 01-08-2006 12:36 PM
Dual channel memory android QnA (read only) 1 24-10-2004 12:19 AM
