My CD Drive now fails to eject or load. Only way I can eject is hard way by using a pointed object inserted into the small hole on front panel.
Now after this problem I have not attempted to load any CDs in it..
Before I throw it off (its more than 4 years old) just wanted to know if something could be done to it. I am planning to open it and see if something can be done
If anybody has ever faced and rectified such a problem, do help.
thanks,
i bet your cd drive is samsung...its known for its faulty trays...
lol, even i have the same problem with my samsng cd-rw...
well i don't know any method which can help you but i can sure help you by telling you a technique with which you can easily eject the drive with a pointed object...
well, you should first press the eject button and then press with the pointed object...this requires a lot less force to eject the drive
try to replace the belt of the rotation part,, from any of the non usable old drive... it should work then.
3d Graphics Animator, //\\ Senior level team Leader
Life is so deep,, that if we try to see in it, we may fall ourselves
