i've just assembled a 2.8 ghz Pentium D procy......earlier i was using an amd sempron 2500+.....ever since i've switched this thing on, it is making much more noise compared to my earlier procy
is this natural or is there any fault with my fan instllation....
try using screw up tightly with the cabined... and also avoid the touching of wires and cables inside to the fan...
3d Graphics Animator, //\\ Senior level team Leader
Life is so deep,, that if we try to see in it, we may fall ourselves
