Re: CdRom stops working suddenly
just open disconnect all the cables and pull from the cabinet and if possible u make open the topcover and make some cleaning with gently without any hard pressure over the components,, and also try a cdlens cleaner ,, then fix all the covers screws and all the cables back ,, then try to power it and test,, if then also it fails to read,
then no way to use it , just dump to old stock and replace with new ones...
3d Graphics Animator, //\\ Senior level team Leader
Life is so deep,, that if we try to see in it, we may fall ourselves
