ok guys it worked for me thanks techno funky ...
heres what i did:
first download
this
open advanced display settings
color management
devices
in devices chk the Use my settings box just below the device
then go to the all profiles tab
add the new profile (i added the adobe 1 from the rgb folder)
then go back to devices
now delete the existing profile
select add and then add the file u just added in the other menu (the adobe wala)
then click on profiles - and select the combine with default option ....
this should do it, if not then just fiddle around with the menus it will be done
