Wel tel me one thing fellas..the Core 2 Duo (E6300 specifically) is a 64-bit Chip right? then why is that in the Device Manager it says x86 architechture and not x64?.
Earth is full.Go home.
Agree with saurav cheeta. It is only EMT64 that makes them capable of 64 bit computing but they are not 64 bit. The name itself denotes that [extended memory technology]. This is just stop gap arrangement from intel.
Stop gap arrangement ???? till what ?
What does 'Its not 64bit' mean ? When used with 64 Bit Applications,it works as a 64 bit processor.
its based on x86-64 technology as many of you must be knowing that single means true 64 bit were failed.. so the company made x86-64(AMD)(and please dont say intel made it first) to run 32 bit applications too... its a 64 bit proccy, but whats there to panic, coz its only to support more memory... thats it, and the dies and cores etc. are still x86 based. they cant still make it full X64 , there will be full x64 when the world will have all x64 applications, till then x85 will also be there... and YES
NISHANT IS RIGHT,install x64 windows and it will show you x64 based PC
hmmm... thx for the gud discussion.... i got the doubt when someone wrote the device manager shud show x64 if u wanna install windows xp 64 bit version.
