Old 03-04-2007, 10:02 AM   #1 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Red face DVD writing problem.....
Im having a very strange problem wid my DW-Q120A sony dvd writer......when i burn cd's no probs at all cd's work fine...even burned ones!......its able to read all kinds of DVD's....but the problem starts when i try to burn DVD's ..all the dvd get wasted in the same manner ....the way in which the dvd is being burned and and wasted is the same ( the same is the problem wid 2 of my friends both use different writers and different media) when we compared our wasted dvd's ...we noticed that all were exactly similar ...even those dvd's which were burnrd successfully but were not working were similar..we have tried nero...roxio..sonic..and the windows inbuilt software..but to no help..all the drivers and firmwares are latest..the same problem persists when i try to burn images using alcohol 120%....i have used 5 different brands of media(sony.moserbaer,alfa,writex,mitsubishi)..and have tried all possible burning speeds...also tried disk drive cleaners..but this also didnt hellp...also our windows are different! ..when i checked the alcohol 120% log file it just sau=id an write error occured and noting else! ppll plZZZZZZZZZZZZZZZZZZZZZZZZZZZ help!!!!!!!!!
Wadadadada!! ??
Ambar is offline
Old 03-04-2007, 04:52 PM   #2 (permalink)
"MKIN WAY 2 android"
Orionz's Avatar
Smile Re: DVD writing problem.....
Same pro happend with my brother also
He replaced is AW-G170A DVD RAM Drive with New One.
Your DRIVE IS ALSO OEM VER OF SONY
CHECK http://liggydee.cdfreaks.com/
FOR LATEST FIRMWARE FOR YOUR DRIVE.
PROB IN OPTICAL DRIVE NEVER BEEN SOLVED
GO FOR FOR BRANDED SONY DRIVE WHICH IS BOXED PACKED.
Orionz is offline
Old 03-04-2007, 04:56 PM   #3 (permalink)
Search for Adventure
ITTechPerson's Avatar
Default Re: DVD writing problem.....
change ur drive now
buy a branded one
Nobody is Perfect. I am "Nobody"
ITTechPerson is offline
Old 04-04-2007, 09:30 AM   #4 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Thumbs up Re: DVD writing problem.....
thnks im buying a liteon lightscribe one now...!!!
Wadadadada!! ??
Ambar is offline
Old 04-04-2007, 09:51 AM   #5 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
didja check out for 4.5GB empty space in the burning software's working directory(it's cache directory)?
koolbluez is offline
Old 04-04-2007, 06:26 PM   #6 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Red face Re: DVD writing problem.....
ya there was around 20 GB free space in the drive !
Wadadadada!! ??
Ambar is offline
Old 04-04-2007, 07:10 PM   #7 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
And.. scandiskked for bad sectors too... slow computer run speed... crap like that... only then blame the drive, as ur repair-centre guy'll anyway ask u to check it out.
Old 05-04-2007, 09:00 AM   #8 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Talking Re: DVD writing problem.....
pc is as fast as ever and they just changed the writer and the prob is solved!!!...thnks ppl!
Wadadadada!! ??
Ambar is offline
DVD writing problem sreenivasj Software Q&A 5 12-03-2007 12:46 PM
Problem writing DVD zegulas QnA (read only) 7 12-09-2006 11:34 AM
DVD writing Problem Him007 QnA (read only) 1 04-02-2006 02:59 PM
CD Writing problem chitvan QnA (read only) 16 11-01-2006 12:56 AM
DVD Writing problem !! hittheswitch QnA (read only) 1 16-08-2005 06:14 AM
