Old 02-04-2007, 08:27 PM   #1 (permalink)
Default formated C:. after that, no Sound
dear experts,
i m using P4 2.3. (Mother Board=ASHROK) onboard Display and Sound Card. done 4 partition. due to virus problem, i have formatted C: and installed Win XP with bootup disc. bt afterwards, NO SOUND.
pls,i m in urgent, be kind to give solution
thanks in advance
waiting wt lov
mobileman is offline
Old 02-04-2007, 08:37 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: formated C:. after that, no Sound
check from DIRECTX if u get any error..adn post here...
which directx u have??
wizrulz is offline
Old 02-04-2007, 08:44 PM   #3 (permalink)
GeekyBoy's Avatar
Have you installed the Sound Drivers from your Motherboard CD? If not install it.
GeekyBoy is offline
Old 02-04-2007, 08:48 PM   #4 (permalink)
Kiran.dks's Avatar
First of all did you install Windows XP Service Pack 2 ? It is a must for playing sounds and Video.
Kiran Kumar R
Kiran.dks is offline
Old 02-04-2007, 08:52 PM   #5 (permalink)
dIgItaL_BrAt's Avatar
how exactly??
dIgItaL_BrAt is offline
Old 02-04-2007, 08:58 PM   #6 (permalink)
a_g = JPKN
s18000rpm's Avatar
not a MUST, but SP2 comes with basic Sound Drivers (correct me if wrong).
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 02-04-2007, 09:07 PM   #7 (permalink)
not exactly...the basic drivers were integrated with the original XP installation itself.
@mobileman: check in the device manager.it's most probably a driver conflict.
Old 02-04-2007, 09:13 PM   #8 (permalink)
a_g = JPKN
s18000rpm's Avatar
hmm didnt know that, thnx for correcting me
but i had problems when using XP Pro (non SP2), windows audio did not work & Audio drivers (frm HP site) refused to install (UAA error), but the original Realtek drivers got installed smoothly.
but anyways thnx
Old 03-04-2007, 09:32 AM   #9 (permalink)
Kiran.dks's Avatar
To Digital Brat and S18000rpm,
There are audio and video playback issues if Windows XP SP2 is not installed. This is because microsoft has bundled lot of compatible drivers with SP2. SP1 drivers are not fully compatible with most of the latest vendors. Hence 9 out of 10 people will experience audio and video playback problems with only SP1 installed. Hence it is essential to upgrade to SP2.
Kiran Kumar R
Old 03-04-2007, 11:44 PM   #10 (permalink)
Default Re:i have installed XP SP2, still no sound,
hi all,
thanks for responses. well i have installed SP2. still no sound. any one can do me a favor ?
tht,the sonund driver for p4 2.4 ashrok Mother Board, is having someone,pls do share.
thanking in advance
Old 03-04-2007, 11:56 PM   #11 (permalink)
a_g = JPKN
s18000rpm's Avatar
is your P4 2.4GHz a LGA775 socket one?
then go & look for you m/b model here http://www.asrock.com/mb/index.asp?s=775
or if its Socket 478, then here - http://www.asrock.com/mb/index.asp?s=478
Old 04-04-2007, 12:27 AM   #12 (permalink)
Google Bot
Pathik's Avatar
is it a asrock i45gv?
Pathik is offline
Old 06-04-2007, 09:00 AM   #13 (permalink)
hi,
no,its Asrock Perscott 533. and P4i45GV. i have dwnloaded sound driver frm Asrock portel. while installation, its asking "cmuda.sys". i cant find this file,any where in my pc.
how can i rectify this?
Old 06-04-2007, 09:03 AM   #14 (permalink)
Kiran.dks's Avatar
Originally Posted by mobileman
hi,
cmuda.sys should be located at C:\Windows\System32\drivers...Can you find it?
Kiran Kumar R
Old 06-04-2007, 09:08 AM   #15 (permalink)
kiran,
i have checkd in System32. bt not there.
Old 06-04-2007, 09:12 AM   #16 (permalink)
a_g = JPKN
s18000rpm's Avatar
download the drivers from Realtek website
Realtek AC '97 Drivers
Old 06-04-2007, 09:31 AM   #17 (permalink)
Dear,
no, the link is not working.i cant get any response nor display
Old 06-04-2007, 09:47 AM   #18 (permalink)
a_g = JPKN
s18000rpm's Avatar
its working fine here
anyways here's direct link to drivers, see if it works ftp://202.65.194.211/pc/audio/WDM_A399.exe
Old 06-04-2007, 10:26 AM   #19 (permalink)
Kiran.dks's Avatar
kiran,
That means Sound Drivers are missing. You should install Sound Driver. Link given by S18000rpm is valid. You should be able to download it.
Kiran Kumar R
Old 06-04-2007, 12:43 PM   #20 (permalink)
harikatt's Avatar
first of all disable the sound card from the cmos setting while at boot,, then boot to your windows xp normally and remove the audio devices if u found in your control pannel > system > from there devices ,,
then reboot,, cleanly,, again on the 3rd boot,, make the sound card active from disable state. one u boot this time wait and see,, the xp will automatically find the driver and may ask for the xp source CD,, then proceed,,
try this way,,, you may get succeed..
3d Graphics Animator, //\\ Senior level team Leader
Life is so deep,, that if we try to see in it, we may fall ourselves
harikatt is offline
Old 07-04-2007, 08:31 AM   #21 (permalink)
dear s18000rpm,
thanki u.i have downloaded. i will try at night.and let u knw.
again thanking u
hi,
well, this driver is not belonging to XP, i think.it may be upto Windows ME.
well, wht my doubt is, if i m getting a group of the 'sys' files, i can drain out my problem,naaa?
help / guidance needed.
Recovery of Quick Formated DVD zegulas QnA (read only) 1 29-11-2006 07:59 PM
Hissing Sound/Disturbance Coming From Speakers/Sound Card ! mikeon Audio 8 15-10-2006 10:37 AM
Ubuntu 5.10 creative vibra128 sound card -no sound smurthygr Open Source 8 25-01-2006 11:59 PM
Formated Window Butterfly Software Q&A 4 14-12-2004 11:31 AM
