Old 02-04-2007, 07:37 PM   #1 (permalink)
shyamno's Avatar
Question DVD writer problem...
I am facing a quite strange problem with my DVD-RW ...Whenever I write something on a CD-RW..and then try to copy the things on my HDD ..it doesn't copy..sometimes..it gives..some error and some times the time goes on increasing..I have even tried it with my friend's DVD-RW..same problem..
But when written on a DVD-R..there is no problem..in copying..
Recently I have updated my firmware..is there any problem associated with that ..
Please help me !!
shyamno is offline
Old 02-04-2007, 09:30 PM   #2 (permalink)
Alive Again...
satyamy's Avatar
Default Re: DVD writer problem...
which OS...........?
which software do you use to burn your CD/DVD..........?
try chaning the SW
satyamy is offline
Old 02-04-2007, 09:59 PM   #3 (permalink)
shyamno's Avatar
windows XP...
I use Nero..but I don't think it is a s/w problem bcoz I am having no problem in burning DVDs..only CD-RW..(RW are fine)..
shyamno is offline
Old 02-04-2007, 10:16 PM   #4 (permalink)
The joy Of Wow
kirangp's Avatar
Dude I think it is a problem with DVD Writer itself.I used to burn DVDs with Gigabyte DVD writer but soon developed a problem of not burning it. I used my friend's Samsung drive & it also gave me the same problem...After that I got another friend's LG drive & it worked properly...The lens that they use in DVD Writers are crap...Otherwise how will you get DVD Writers for RS 2000??? The writers nowadays suck big time
The right man in the wrong place can make all the difference in the world
kirangp is offline
Old 02-04-2007, 10:35 PM   #5 (permalink)
nishant_nms's Avatar
Flash ur drive's firmare with the most recent one visit manufacturer's site for latest release. Use the firmware for ur drive model only
nishant_nms is offline
Old 02-04-2007, 10:52 PM   #6 (permalink)
Self-Obsession
hittheswitch's Avatar
No use.... Your drive is dead now.... u can use it only for writing DVDs....
This happened with me also... LG service centre is also not able to repair.... You flashed with the wrong version....
Its a very common problem. The only chance u have is that if your DVD writer is under warranty,get it replaced.....
I'm walking between mads,but whats the use i'm still the worst one.
hittheswitch is offline
Old 02-04-2007, 11:04 PM   #7 (permalink)
Alive Again...
satyamy's Avatar
than the only thing can be your Cable which connect your DVD Writer & Motherboard
Use a High Quality 40Pin Cable
r u also getting error in reading autorun CD's or DVD's.................?
satyamy is offline
Old 03-04-2007, 07:11 AM   #8 (permalink)
shyamno's Avatar
..I am not getting any burning errors...and I have not used any other wrong version firmware..to update my current model of DVD-RW...
I am having a CD-RW..and a DVD-RW.both are having the same problem...no burning error..but when copying the materials from a CD-RW...it gives error..
Also I want to know that...when Updating the firmware...does I need to unplug the other optical drive beside the one which I m updating....
Can I go back to the earlier firmware.. ???
My DVD-RW in connected as slave and CD-RW as master,can it be a problem..???
Can I go back to the previous one ..or before..the latest ones ???
Suppose I was having YYS3..and then upgrade it to YYS7..now can I go to YYS3 or YYS6...
shyamno is offline
Old 03-04-2007, 04:54 PM   #9 (permalink)
"MKIN WAY 2 android"
Orionz's Avatar
Try Onather Dvd-rw Media
May Be It Will Solve Your Problem
Orionz is offline
Problem With My DVD Writer ??? navino87 Hardware Q&A 2 05-01-2007 09:58 PM
Writer Problem ra_sriniketan QnA (read only) 10 04-09-2005 05:35 PM
CD-writer problem abhijit_reddevil QnA (read only) 9 11-08-2005 05:38 PM
Problem with DVD Writer sourabh_nandi QnA (read only) 3 26-08-2004 07:22 PM
