Old 01-04-2007, 04:55 PM   #1 (permalink)
Anindya's Avatar
Question Plz build me a cpu within Rs.15k.
Plz build me a cpu within Rs.15k. I only want to upgrade the cpu. It can be either aan Intel or an Amd based. It must posses a basic graphics card. Plz give the price and the company also. Also tell me whether i will be able to use my surrent PATA 40gb HDD with SATA II in the same m/b or not?
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
Old 02-04-2007, 01:25 AM   #2 (permalink)
"MKIN WAY 2 android"
Orionz's Avatar
Default Re: Plz build me a cpu within Rs.15k.
check out the cost of hardware in digit mag
n you will be able to take controle on your budget.
in 10k lots of best board n processor are available.
Orionz is offline
Old 02-04-2007, 08:01 AM   #3 (permalink)
assasin's Avatar
C2D E6300 & MSI P965 Neo-F
if u want onboard gfx then buy Intel DG965WH/DG965RY.
u'll hav to buy ddr2 ram to pair with these mobos.
assasin is offline
Old 02-04-2007, 10:20 AM   #4 (permalink)
MMO Addict
amitava82's Avatar
http://www.computerwarehousepricelist.com/build.asp
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Help me build a PC under 70 - 80K piyushp_20 Hardware Q&A 30 07-01-2007 06:45 AM
Need help to build a rig troubleshooter QnA (read only) 8 14-09-2006 04:39 PM
Help Me Build my PC! Jikx Hardware Q&A 21 06-09-2006 09:41 PM
Help me build a PC sagargv QnA (read only) 10 10-08-2006 07:18 PM
Please help me to build my new pc birbal Hardware Q&A 14 14-07-2006 09:09 AM
