30-03-2007, 05:26 PM
AMD processor & Mobo
hey all
can someone pls suggest a good amd processor/mobo(with integrated graphics) combo for arnd 10 k?
thanks
30-03-2007, 06:32 PM
Re: AMD processor & Mobo
X2 3800+ and Asus M2N-MX
30-03-2007, 06:34 PM
go for a nvidi128Mb graphic card for abt 4-5K
30-03-2007, 08:23 PM
@Tech Geek
Hi, which world are u living??Nowa days a gcard is not judged by its memory only. For 5k u cud even get a 7300GT 512 DDR3. But a 6600GT 128[6k] cud easily outperform it.
So @azad
ur best deal is the one suggested by assasin.
M2N MX : 4k
X2 3800+ : 6.1k
X2: 3600+ : 5.5k
M2N MX has good onboard GFX[6100] and 3800+ is a gud deal for 6k range.
G3: XPS M1530 |
FZ 16.
31-03-2007, 07:08 AM
thanks all, but can u pls tell me if i shld go in for a M2NMX or a M2NPV- VM?
08-04-2007, 01:20 PM
i also want to buy a Athlon 64 X2 3800+ with a good motherboard , which one is good in between these ?
M2NPV-VM Asus (Socket AM2) Rs.4600
or
M2N-E Asus (Socket AM2) Rs.6150
these prices are from www.theitwares.com...
which one should i buy ,
please reply.. fast...
thanks
08-04-2007, 01:38 PM
Learner
Hey M2N-E is a great motherboard, couple it with a gcard and u are set to go, good OC'ing features
08-04-2007, 01:51 PM
if u goin for amd am2 than ull have to go 4 ddr 2 than its better to get c2d though right now above budget...but on 22nd april there is slight price fall ull get both cpu and mobo in 10k range which is faster than am2
08-04-2007, 02:15 PM
Google Bot
go 4 a m2n pv vm + a x2 3800+
08-04-2007, 08:43 PM
Go for the combo of AMD AM2 4200+ and ASUS M2NPV-VM..for Rs.9650....
09-04-2007, 01:19 AM
at this time my budget for MOBO + CPU + GCARD = Rs 10000,
so if i take the ( M2NPV-VM + Athlon 64 X2 3800+) = Rs. 9100 (approx)
if i take this now then i have to leave the Gcard for later as upgrade....
or
i if i take (M2N-E + Athlon 64 X2 3800+ + 7300GT 256MB) = Rs. 16000
so it is over budget ,
what to do ? any good suggestions ?
and which graphic card u all recommend if i use vista with aero?
and one thing which i am losing in the M2NPV-VM mobo is it has only 2 PCI slots ..
i m a bit confused...
09-04-2007, 09:03 AM
^^^ i'll suggest u to buy wat 'shyamno' suggested.
buy a good mobo + proccy now and buy a gfx card later.
2 pci slots r enough i think.
09-04-2007, 11:31 AM
I have decided to go for X2 4600+ or 4800+ & mobo M2NPV-VM.
1) Is this mobo is future proof ; can i later upgrade to quad core and DX 10 card.
2) what does this means "2.5GHz 1MB L2 cache ".
Single core 2.5 or both combine 2.5 also 1MB for single core or shared
by both.
09-04-2007, 07:03 PM
^^^ each core will run @ 2.5GHz.each core has 1MB L2 cache.
09-04-2007, 09:19 PM
Back to l33ching :)
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
hi guys, my friend wants to upgrade his mobo+proccy n ram. his budget is around 10k max. can u plz suggest a good combo for this?
btw....heard that AMD will be slashing its prices today....so take that into account as well....tho i doubt whether it wud be so soon in India.
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
09-04-2007, 11:25 PM
hold on till the end of this month.Intel is also scheduled to slash prices by 22nd April.so better buy around mid-May.by that time every thing will be clear.
10-04-2007, 07:38 PM
What the differences in the properties of Radeon X1250 and Nvidia Geforce 6150 ?????
The optical drives..are connected via IDE..port and does IDE and ATA ..means the same..
Suppose If any mobo supports only 1 ATA..port ..then how many devices can be connected..??
Does optical drives uses only IDE interface..???Then every mobo have to support ATA..or does they support other interface also ???
I also want to know that...Can I use both ATA and SATA HDDs simultaneously..connected together if not what may be the problem and what have to been done ??how can these two combinations be worked ..out one ATA(40GB) another SATA(120GB) i.e on which the OS should be installed and which should be used as a storage device ??
10-04-2007, 09:14 PM
i feel today a AD was published by HP desktop bundle,, its good configuration with 1GB RAm and other configs,, with LCD monitor ,, all around 12k..
just find out the hp site.. for more details.
3d Graphics Animator, //\\ Senior level team Leader
Life is so deep,, that if we try to see in it, we may fall ourselves
10-04-2007, 09:29 PM
#19 (permalink)
can u give the exact link?
11-04-2007, 05:23 AM
#20 (permalink)
just for my interest I wud like to know wat would be Amd's equivalent of Intel's E6600 + asus p5n32 e sli ?
C2D E6600,Asus P5N32 e SLI,1GB 667mhz,Samsung 940BW,Zeb 8600GT,Seagate 250GB sata II,16x Sony(OEM) dvd RW,Zeb Anitibiotic & Platinum 500W,Microsoft desktop pro 700,bluetooth,Logitech MX Revolution
11-04-2007, 08:05 AM
#21 (permalink)
e6600 beats amd fx processor no equivalent so far...
btw amd has reduced price so decide according to your need..price will reflect in 2 weeks here
http://www.dailytech.com/article.aspx?newsid=6848
* Model ( Previous Price to New Price )
* X2 6000+ ( $464 to 241 )
* X2 5600+ ( $326 to $188 )
* X2 5200+ ( $232 to $178 )
* X2 5000+ ( $222 to $167 )
* X2 4800+ ( $217 to $136 )
* X2 4400+ ( $170 to $121 )
* X2 4000+ ( $144 to $104 )
* X2 3800+ ( $113 to $83 )
* X2 3600+ ( $102 to $73 )
11-04-2007, 09:08 PM
#22 (permalink)
My friend recently bought ASUS M2N PV VM..now the problem is that his ATA HDD and the CD-RW is not detecting..in the bios...what may be the problem ??
Can both ATA and SATA HDD be used and access together ???
11-04-2007, 11:26 PM
#23 (permalink)
Yes both ATA and SATA devices (HDD/optical drives) can be used and accessed together at the same time.
try changing the IDE cable,try updating BIOS.
12-04-2007, 01:19 AM
#24 (permalink)
at last i have decided to go for this mobo and proccy, now please tell me some queries ...
is this motherboard future proof ?
does this support full vista ?
anything else do i need which is not available in this board ?
please reply,..
12-04-2007, 01:34 AM
#25 (permalink)
M2N PV Vm is a nice Mobo
nVIDIA Socket AM2 Motherboard (Vista certified)
nVIDIA GeForce 6150 + nForce 430
Dual-channel DDR2 800/667/533
PCI Express architecture
Integrated GeForce6 GPU
Dual VGA Ouput: DVI-D & RGB
HDTV out interface (HDTV/AV/S output module was bundled)
12-04-2007, 01:39 AM
#26 (permalink)
Learner
AMD X2 6000+ = E6600
12-04-2007, 05:09 AM
#29 (permalink)
thnx bro and
wat about the motherboard;
wat's asus p5n32 e sli 's AMD based equilvalent?
12-04-2007, 06:22 AM
#30 (permalink)
Can the optical drives be connected through SATA...interface instead of IDE(ATA) interface..???
IDE and ATA means the same thing or different ??
