Old 30-03-2007, 01:51 AM   #1 (permalink)
ECE0105's Avatar
Question Dataone Wireless....
Hi people.
I have a dataone connection at home and a Huawei MT8800 ADSL Modem.
Is it possible to use a Wireless router instead of the ADSL?
What would be the cost of a normal Wireless Router/Modem and a Wireless adapter for my PC?
And, is it possible to connect more than one Computer at the sametime to the Wireless?
Awaiting responses....
Some of the happiest people in the world do NOT have Everything... They just make the Best of Everything life brings their way... So, Stay HaPpY.... Smile Always.... :-)
ECE0105 is offline
Old 30-03-2007, 12:18 PM   #2 (permalink)
dissel's Avatar
Default Re: Dataone Wireless....
Yes tou can buy a wireless router/access point instead of full Wireless ADSL Router.
Coz you have the ADSL modem already have.
If your computer don't have onboard support of Wi-Fi you need to buy a USB wireless adopter
According Digit Jan '07
Wireless Router:-
Best Buy Gold - ASUS WL-530G ---4400/-
Best Buy Silver - Linksys WRT54G----3634/-
Access Points:-
Best Buy Gold - Linksys WAT54G ----3816/-
Best Buy Silver - Senao ECB3220 ----8280/-
The above price is in MRP in Jan 07....You defiantly got lower price in your place.
The router/access point and the Wireless adopter have same Wi-Fi specification (Recommended)
dissel is offline
Old 30-03-2007, 02:06 PM   #3 (permalink)
ECE0105's Avatar
Thanks for the reply dude...
The ADSL Modem that I have is provided by BSNL on rental basis. I wanna change that and move on to a full wireless router/modem.
As I understand, if you have a wireless, you can also use it as a wired router. Is that right?
And, can I share the internet connection?
ECE0105 is offline
Old 30-03-2007, 02:24 PM   #4 (permalink)
sivarap's Avatar
@ECE0105
You are right you can use it as a wired router also. and as in other routers u can also share the internet. The one i use at home is a DLink one. I guess i cost only less than 3k. If u have any problem configuring it, gimme a buzz i'll help you.
@Dissel
whats teh diff b/w a access point and wireless router? I tht both are synonymous.
sivarap is offline
Old 30-03-2007, 07:20 PM   #5 (permalink)
dissel's Avatar
Digit Reviewd 2 ADSL Wi-Fi Router (All-In-One Device)
ASUS WL-600G --- 8500/-
Netgear DG834G --- 4230/-
Later one is most popular, I seen many forum's talking about it .
Yes.
An access point simply maintain the Wireless Network without routing function.
dissel is offline
Old 30-03-2007, 07:55 PM   #6 (permalink)
Distinguished Member
anandk's Avatar
thanx dissel.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 31-03-2007, 12:56 AM   #7 (permalink)
ECE0105's Avatar
Thanks for the replies guys....
BSNL is providing modems for outright purchase : Type-II with 1 Ethernet and 1 Wifi port and Type-IV with 4 Ethernet and 1 Wifi ports....
Any insight into this?
ECE0105 is offline
How to go wireless? x7r3m3 Hardware Q&A 7 17-01-2007 01:16 AM
Wireless lan, help. Kniwor Networking 7 18-01-2006 04:47 AM
wireless lan shivi4 Networking 4 25-12-2005 10:47 PM
how to set up Wireless LAN? susk21 Networking 11 16-11-2005 02:07 AM
