Old 28-03-2007, 05:12 PM   #1 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
Default can i add a dvd writer on a P-II machine?
i am buyin a new dvd writer
i want to back up all my mp3's on my P-II machine
specs r
P-II 266 mhz
32 mb ram
windows ME
will the pc be able to burn dvd's with 32 mb ram & p-II processor ?
will there be any buffer under run error?
& r there any particular precautions i should take while installing the writer / how should i install the writer(instructions)
thanx for any help
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ThinkDigit Forum Workspace Showoff Contest
ssk_the_gr8 is online now
Old 28-03-2007, 05:18 PM   #2 (permalink)
gEttIn 0uT@@@ BOXX
abhi1301's Avatar
Default Re: can i add a dvd writer on a P-II machine?
i don't think the hardware should have any problem but u won't get the proper software 2 burn the dvd . it's better u plug uer hard disk 2 a frens comp & make uer bakup from there
Add reps if this works
Koi CHAKAR NAHI HAI >> SAB JUGAAD HAI
abhi1301 is offline
Old 28-03-2007, 05:22 PM   #3 (permalink)
abhishek_sharma's Avatar
32 mb ram will have probs writing dvds properly...best is what abhi suggested.
take out the hdd from ur comp...put into a new comp and backup all the data...
abhishek_sharma is offline
Old 28-03-2007, 06:08 PM   #4 (permalink)
ds_rajat's Avatar
ssk, 32 mb ram is not good enuf for dvd burning. look at the booklet for minimum config. i think u need a min of 128 mb ram for dvd burning.
ssk... if u want 2 take only mp3 backup, then why don't u install a cd-writer?
My PC My World
ds_rajat is offline
Old 28-03-2007, 06:24 PM   #5 (permalink)
Google Bot
Pathik's Avatar
forget dvd burning on 32mb...
Pathik is offline
Old 28-03-2007, 10:37 PM   #6 (permalink)
cnt do it as i have 6 gb of mp3
will backup mp3 by transferin hdd
thanx
Old 29-03-2007, 05:50 PM   #7 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
problem CHILD .......... 32 mb RAM not enough ..........
RUN 2 ur frds PC >>> plugin & right >>> & come back home, RELAXED ..........
ax3 is offline
Old 29-03-2007, 09:24 PM   #8 (permalink)
already done that
Will Serious Sam 2 run on my machine? bukaida Gamerz 1 15-11-2006 01:10 PM
ASP.NET Machine A... gambit QnA (read only) 1 17-07-2005 05:40 AM
Old Machine Problems sachin_kothari QnA (read only) 2 06-01-2005 05:14 PM
