Old 28-03-2007, 01:39 PM   #1 (permalink)
bajaj151's Avatar
Default Asus MOBO ????
Hi.....
I am planning to buy Motherboard with Processor that supports Quad-Core .....DDR3....
So tell me...of which brand and model should I go for........
I want the best one....no matter whts the price is........
Is there any other board available which beats:Asus P5N32-SLI SE Deluxe....If yes...tell me....and also tell me its approx price...in delhi
Thx in advance
bajaj151 is online now
Old 28-03-2007, 01:54 PM   #2 (permalink)
assasin's Avatar
Default Re: Asus MOBO ????
ddr3 ram chips r only used in gfx cards at present not in system memory.
so u wont get a mobo with ddr3 support
assasin is offline
Old 28-03-2007, 02:02 PM   #3 (permalink)
Even I was wondering that where did he read ddr3 ram support in the mobo ???
DDR2 to milti nahi hai yahan pe DDR3 na jaane kab aayegi!
ranjan2001 is offline
Old 28-03-2007, 05:25 PM   #4 (permalink)
premsharma's Avatar
What FSB would be of DDR 3. I think from 533 mhz to 800 mhz is DDR2 ??
premsharma is offline
Old 28-03-2007, 05:32 PM   #5 (permalink)
gEttIn 0uT@@@ BOXX
abhi1301's Avatar
You are very right my frnd ..
The DDR3 SDRAM devices will offer data transfer rates up to 1600 Mbps (megabits per second)
source http://www.simmtester.com/page/news/...ws.asp?num=145
Koi CHAKAR NAHI HAI >> SAB JUGAAD HAI
abhi1301 is offline
Old 28-03-2007, 06:46 PM   #6 (permalink)
darklord's Avatar
Intel G35/P35 or better known as 'Bearlake' chipsets are the ones supporting DDR3.Since current boards already support Quad Core,its common sense that the boards based on P35/G35 will support Quad Core.
Motherboards based on these chipsets are just around the corner,not yet launched.Mostly they will be launched in DDR2 models first and then DDR3 ones for better acceptance from the consumers.
DDR3 will debut with speeds of 800,1000,1066,1333 MHz
Later on DDR3 will come in 1600MHz. As was the case with DDR2,Jedec specs have horrible latencies for them.IIRC 1600MHz ones will have CAS 9
Nothing to worry though,performance memory makers will do some extremely high binning and get Kits with lower latencies at high speeds out but it will take time.
DDR3 is rated to work at 1.5V
Expect 4GB kits to be common in the near future and at affordable rates.The future is exciting
darklord is offline
Old 28-03-2007, 07:47 PM   #7 (permalink)
assasin's Avatar
Yeah ECS has come out witha mobo based on P35 chipset (ECS P35T-A) which supports both DDR2 as well as DDR3 mem types,but only one mem type can be used at a time.
these new chipsets from Intel will hav native support for 45nm fabricated proccies.
the best of all these new chipsets will be X38 which will sport support for only DDR3 and dual pci-e x16 gfx slots.X38 will repplace Intel 975 chipset.
assasin is offline
Old 28-03-2007, 10:29 PM   #8 (permalink)
bajaj151's Avatar
thx...for ur suggestion..
I think I shuld wait....for DDR3 +Quad-Core capable mobo.....before spending money on this board.....By d way......how much onboard memory available...on this Asus Mobo.....
Old 28-03-2007, 11:24 PM   #9 (permalink)
assasin's Avatar
wat do u mean by onboard memory???
P5N32-E SLI supports a max of 8GB of installed mem.
as far as DDR3 & Quad Core r concerned,u'll hav to wait 4 bout a year before prices drop and they become mainstream.
assasin is offline
Old 29-03-2007, 01:29 AM   #10 (permalink)
bajaj151's Avatar
Sorry...I was not clear.....by ONBOARD MEMORY....I mean.....onboard graphics memory.......
Old 29-03-2007, 08:09 AM   #11 (permalink)
assasin's Avatar
P5N32-E SLI Dlx mobo doesnt hav onboard gfx.
assasin is offline
A 7900 GTX SLI on a Non SLI ASUS mobo??? capri435 Hardware Q&A 16 14-08-2006 11:11 AM
Which Asus Sli Mobo ? ? ? tiblu Hardware Q&A 2 02-05-2006 11:53 AM
BEST ASUS Mobo for P4 2.66 GHZ Processor!!! Vishal Gupta Hardware Q&A 9 08-12-2005 10:05 PM
PSU to new Asus SLi mobo parimal CPU / Motherboards 7 04-02-2005 11:50 AM
