Old 27-03-2007, 06:15 PM   #1 (permalink)
Desperado's Avatar
Unhappy Lite-ON dvd writer issue: HELPPPPPPPPPPPPPP
hello people,
this is my third thread as my issue is still not resloved since 6 months..
whenever i play movies on my sony dvd writer... it makes some crackling noises and the picture becomes slow i cant use VLC player when watching movies on my dvd player...
the only player which reduces the noise is NERO SHOWTIME....
without noises:
.avi files work in windows media player sumtimes.
.VOB files works good with Nero SHowtime player...
due to this my friends gifted me a lite-ON dvd writer .. its the same issue again... we have tried changing the cables , changing the IDE modes... no luck at all. MOVIES SAVED ON MY HARD DISK WORKS PERRRFECT. but cant play them on dvd player...
i am pretty frustrated with this.. seems like a motherboard issue or sumthing..
any help wud be greatly appreciated.
Friendly Neighbourhood,
Shahid
Desperado is offline
Old 27-03-2007, 06:26 PM   #2 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Default Re: Lite-ON dvd writer issue: HELPPPPPPPPPPPPPP
I once had this type of issue with my hard disk
Whenever i tried to copy data from my master harddisk, i would get an error that the slave harddisk had some write error
Then when i checked, I found that one of the pins (IDE) on the harddisk was bent and two were broken
I soldered new pins in the slot and and now it works like before
There can be multiple issues for your problem
1.Firmware
2.Motherboard IDE Slot Issue
3.Master or Slave configuration conflicts
Please let me know how have you configured your Hard Disks with DVD-ROM/RW
techtronic is offline
Old 27-03-2007, 06:43 PM   #3 (permalink)
Lightbulb Reg : My Dumbass Friend
Hi... I m Desperado's friend. Lemme tell u the HDD n DVD-RW config.
The HDD is set as Primary Master and DVD-RW is set as Secondary Master. Both set on separate channels.
Warm Regards,
ISRAR AMRELIA
israramrelia is offline
Old 27-03-2007, 06:56 PM   #4 (permalink)
darklord's Avatar
^^ Well....err flashed the firmware to RPC1 ?
Maybe that can help
darklord is offline
Old 27-03-2007, 07:05 PM   #5 (permalink)
Desperado's Avatar
well plzzz take this seriously.... i have been facing this issue since 6-7 months..
and i feel bad for my friends who have gifted me a new dvd player..
Shahid
Old 27-03-2007, 07:19 PM   #6 (permalink)
The Transcendental
Check whether you have enabled DMA (Direct Memory Access) for your drives in Device Manager.
Enable it if not.
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
..:: Free Radical ::.. is offline
Old 28-03-2007, 02:39 PM   #7 (permalink)
Desperado's Avatar
if u mean the primary channel IDE....then .. DMA is enabled..
but secondary channel is PIO only...
if secondary channel is DMA = it wont play the movie at all..
Shahid
Old 28-03-2007, 06:48 PM   #8 (permalink)
darklord's Avatar
I am still suggesting updating the firmware buddy
with RPC1 hacked firmware,you can play any Region DVD in your drive.Infact thats the first thing i do whenever i get a new drive
darklord is offline
Old 29-03-2007, 12:28 PM   #9 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
try scandisk, defag 4 ur hdd .........
ax3 is offline
Old 07-04-2007, 03:31 PM   #10 (permalink)
Desperado's Avatar
buddy... i think u didnt get my problem...
i have changed the whole firmware..from a sony dvd writer to Liteon .. but the problem still exists.. so theres no question of updating it..
i repeat ..i can play movies saved on my harddisk without any cracklin noises..
but not with my Liteon dvd writer..
Shahid
Help me buying Lite-On DVD Writer plz prabhatmohit Hardware Q&A 12 23-10-2008 04:38 PM
Lite On LH-20A1P DVD-Writer problem aritrap Hardware Q&A 20 20-09-2007 07:20 PM
Extremely Bizarre DVD writer issue !!! NikhilVerma Hardware Q&A 8 20-10-2006 05:04 AM
Lite-On SHW-160P6S Dual Layer DVD±RW Writer ironcross77 QnA (read only) 5 25-07-2006 10:06 PM
Lite-On DVD Writer Sam Fisher QnA (read only) 2 09-05-2006 02:27 PM
